Old 04-15-2021, 10:05 AM   #1
Riftur
Riftur's Avatar
Add HP/torque 2013 FRS
So I was planning on waiting for the rumored Turbo 86 but unfortunately, it was just a rumor. Most likely, since Covid hit and my finances also took a hit, I am looking for the best/cheapest way to get the car hp to 200whp without using an expensive forced induction kit. Is it even possible and if so, what needs to be upgraded to get there? Thanks
Riftur is offline   Reply With Quote
Old 04-15-2021, 10:14 AM   #2
fminicooper
Drives: FRS Hot Lava
Decatt OEM header (you will spend $25 in new gasket)
OFT used ($350/$400)
E85 if available in your area.
fminicooper is offline   Reply With Quote
Old 04-15-2021, 10:20 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
/endthread
Old 04-15-2021, 10:32 AM   #4
Riftur
Riftur's Avatar
I have the OFT already and running on e85 adds (total guess, 15-20 HP) but there are not enough stations that sell e85 around me which is a problem. Would a flex fuel kit solve this issue so I do not have to plan everything around when I need to add fuel.
Old 04-15-2021, 10:38 AM   #5
Riftur
Riftur's Avatar
Is this the header you recommended?
https://www.ebay.com/itm/Toyota-GT86...0AAOSwJ8pbbM4b
Old 04-15-2021, 10:46 AM   #6
WNDSRFR
Drives: FR-S,GTI
Keep your eye out for a used Phantom ESC. Should get you up to about 200 WHP about the cheapest way you can go. And it can be installed/deinstalled pretty easily.
Old 04-15-2021, 10:49 AM   #7
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
E85 is going to be the easiest way to get 200whp and safely. But if it's not available....
The alternative is a EL header like the Ace A350 (pricey), 93 octane:
https://www.ft86club.com/forums/showthread.php?t=121460
According to this thread, 91 octane is going to net you 195whp here, so 93 might get you the extra 5. Either way, it's at last in the ballpark and not going the e85 route.
Alternatively, you're looking at a flex fuel kit and running e85 when you can get it, which should put you over the 200whp barrier.
cmiovino is offline   Reply With Quote
Old 04-15-2021, 11:32 AM   #8
Riftur
Riftur's Avatar
Is there a flex fuel kit that you would suggest? I have a station 4 miles from my house that sells e85 but I hate having to plan around fueling up my car, especially if I am in a rush and need gas.
Old 04-15-2021, 11:35 AM   #9
Riftur
Riftur's Avatar
Just to verify, is this the one?
https://www.ft86club.com/forums/showthread.php?t=144933
Old 04-15-2021, 01:14 PM   #10
PulsarBeeerz
Drives: JRSC BRZ SOLD
There's not a need to decat if running E85. You don't get anymore power or kill the tq dip. Just noise and smell.
PulsarBeeerz is offline   Reply With Quote
Old 04-15-2021, 01:20 PM   #11
tomm.brz
Drives: brz 2017 hksv2
true, pretty easy to reach MBT while NA with pure e85 also with a cat
the gains would be marginal
Old 04-15-2021, 02:54 PM   #12
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
"decat OEM header" just means punching/chiseling the cat out of a stock header (cheap/free!), which you can do with a long screwdriver and a hammer. Just make sure to wear a breathing mask, those particles are toxic.
NLSP is offline   Reply With Quote
Old 04-15-2021, 03:17 PM   #13
Riftur
Riftur's Avatar
oh dam I had no idea, are you able to point me to a guide on how to do it?
Thanks!
Old 04-15-2021, 04:05 PM   #14
NLSP
NLSP's Avatar
Thanks!
I don't recall anybody on the forum posting any visuals/guides, but I found this YouTube video. Basically what he starts doing at the 4:00 mark:
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 04:02 PM
Requested torque and Calculated torque nickw14 Software Tuning 3 06-13-2015 04:09 AM
Why the low torque? Ds3ire Scion FR-S / Toyota 86 GT86 General Forum 144 11-28-2014 11:49 AM
Torque Dip sierra Scion FR-S / Toyota 86 GT86 General Forum 68 07-22-2013 03:18 PM
torque mrnibbs Scion FR-S / Toyota 86 GT86 General Forum 21 05-13-2013 09:37 PM
