Old 04-12-2021, 09:33 PM   #1
ICauseCalamity
Drives: Totaled 2013 Toyota Corolla
HKS GTIII RS Turbo Build Help/Advice
Hello FTFam!
I’m in the process of going turbocharged and I want some advice on parts. I want to know if I’m under doing or overdoing any parts here such as I beams vs H beams being overkill. My horsepower goal is 400whp so I will be building the engine, I will also be running E85 pretty much exclusively so if the Flex Fuel kit from Delicious Tuning isn’t required let me know. Here’s the part list:
Turbo Kit Price Match
https://www.discountbandit.com/hks-8...-kit.html?gs=1
$3978.47
SB8-XTSS ACT Clutch
https://frsport.com/act-sb8-xtss-xt-...h-kit-fr-s-brz
$672.00
HKS Oil Cooler 15004-AT011
https://www.hptautosport.com/product...ant=6766221313
$692.29
Radium Engineering 20-0103 - 13+ Scion FR-S / Subaru BRZ Dual Catch Can Kit
https://www.cspracing.com/radium-eng.../baja-20-0103/
$379.86
HKS M-Series Super Fire Racing Spark Plugs HL Type Heat Range 10
https://www.vividracing.com/-p-15110...hoCmmUQAvD_BwE
$25.89
BRZ/FRS/86 3-PORT EBCS & HKS
https://www.delicioustuning.com/node/367
$149.95
DW 9-307-1010 DW300C Compact Fuel Pump w/o Mounting Clips w/ 1010 Install Kit
https://sportcompactwarehouse.com/dw...D=pwf462546g1&
$151.41
Injector Dynamics USCAR to Denso PnP Adapter
https://www.autohance.com/deatschwer...BoCIY0QAvD_BwE
$12.00
INJECTOR DYNAMICS ID1050 INJECTORS SUBARU BRZ / FA20 2.0L 11 MACHINED TOP WRX-16B BOTTOM ADAPTORS
https://emnotek.com/products/injecto...xoCfUsQAvD_BwE
$520.00
Omni Power MAP Sensor for BRZ S2000 K-Series (Black)
https://stmtuned.com/products/omni-p...32668938928213
$116.99
BRZ/FRS/86 FLEX FUEL BLUETOOTH KIT MK1
https://www.delicioustuning.com/flexfuel
$595.00
Manley I-Beam Turbo Tuff Rods for FA20 BRZ/WRX
https://stmtuned.com/products/manley...23354783039573
$865.57
ACL Rod Bearings
https://www.maperformance.com/produc...xoCdZcQAvD_BwE
$31.58
JE Forged Pistons 86mm 10.5:1 Compression Ratio
https://www.oakos.com/JEP-315117.htm
$580.37
I need some gauges of course any recommendations on those? I’ll probably have to replace the CV joints as well since this is a good jump from stock, I’ve heard mixed reviews about the Driveshaft Shop Pro Level kit. Any help would be appreciated, I’m working with Kinetic Autoworks in MD but if anyone has any recommendations for the tuning and labor let me know as well.
ICauseCalamity is offline   Reply With Quote
Old 04-12-2021, 11:24 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Just buy a Iag stage 2 short block my guy if you're going to do pistons and rods.
Sent from my SM-G998U using Tapatalk
Joveen is offline   Reply With Quote
Old 04-12-2021, 11:59 PM   #3
ICauseCalamity
You think it's gonna be cheaper or is it just a better option? I don't have anywhere to store my OEM block.
Old 04-13-2021, 08:52 AM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Some companies will take the core. i.e. your oem block and reuse it
MS, CSCS, TSAC-F, CPT
Old 04-13-2021, 11:25 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Considering you still need to add main bearings, head studs, and main bolts which are 260ish and 425ish from ARP, along with gaskets. If you are not doing it yourself add labor too, buying a built short block is pretty close in price.
If your engine is in decent shape you could still sell the short block and recoup a good chunk of money.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkPira7e (04-13-2021), ICauseCalamity (04-14-2021)
Old 04-14-2021, 04:02 PM   #6
ICauseCalamity
Doing the IAG Stage 2.
The Following 2 Users Say Thank You to ICauseCalamity For This Useful Post:
NoHaveMSG (04-14-2021), weederr33 (04-14-2021)
HKS GTIII Turbo vs. Jackson Racing C38 ICauseCalamity Forced Induction 17 04-09-2021 02:11 PM
First time FRS build looking for advice/ideas FT86Hypnotic Mid-Atlantic 31 12-10-2015 03:18 PM
Need AutoX Build Advice muffinz Tracking / Autocross / HPDE / Drifting 32 09-12-2014 01:27 PM
Boombacloud's BRZ Audio Build...Need Help/Advice boombacloud Electronics | Audio | NAV | Infotainment 1 12-28-2012 12:35 AM
