Old 04-09-2021, 01:08 PM   #1
gpvecchi
gpvecchi's Avatar
Experts, please, going from Ecutek to HKS?
I bought Ecutek because I converted the EU facelift model to JDM specs (manifolds, final drive, etc, not available in EU) and I used to flash a stock JDM calibration.
Now, I don't need all the features, so I'm planning to sell it; I would like to switch to HKS flash editor (the JDM version, so it has the correct calibrations for my ECU) for a canned tune, even for their specific headers.
Will the HKS Flash Editor identify my ECU as modded, and could it be able to flash it stock/tuned?
Thanks!
gpvecchi is offline   Reply With Quote
Old 04-09-2021, 01:56 PM   #2
tomm.brz
Drives: brz 2017 hksv2
you won't be able to flash it directly
You ll have to flash back to stock and then with another system like hks (or any system) the license will be lost
Are you sure about using hks tune, i have a restyling JDM tune from HKS for supercharger and it's honestly the worst tune i've even seen, they do the bare mininum to the stock tunes to let car run acceptable
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
alphasaur (04-09-2021), gpvecchi (04-10-2021)
Old 04-09-2021, 03:50 PM   #3
Gamace
Gamace's Avatar
Drives: 2012 Toyota 86
Thanks!
Ensure you flash back the ECU to stock before using the HKS Flash Editor to re-flash. I have the HKS Flash Editor with the NA tunes and so far the one I'm on is good enough for me.
Toyota 86 in the building!
Gamace is offline   Reply With Quote
The Following User Says Thank You to Gamace For This Useful Post:
Old 04-09-2021, 04:07 PM   #4
tomm.brz
Gamace, are you able to extract the na tunes from you hks editor ?
they can be flashed with ecutek and keep the licence
The Following User Says Thank You to tomm.brz For This Useful Post:
Old 04-09-2021, 04:08 PM   #5
jflogerzi
jflogerzi's Avatar
Why not just do a remote tune with ecutek?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 04-09-2021, 07:14 PM   #6
Gamace
Gamace's Avatar
I'm not sure to be honest. Meaning to replicate a soft copy of them? I have never tried that before.
Old 04-10-2021, 01:40 AM   #7
tomm.brz
maybe those bin are exctactable , dont know
i got one of those by a guy who read the tune with another system and he read it without problem and now it's flashable by ecutek or tactrix
I don't really need them, they d help gpvecchi to have them without throwing away his ecutek licence and kit
Old 04-10-2021, 04:22 AM   #8
gpvecchi
gpvecchi's Avatar
Thanks as usual Tommy, I still hadn't decided what way follow for my engine. It's more for going all JDM in the meantime...
Anyway, I should flash stock JDM map with Ecutek, then reflash stock with HKS and loose my license, then I can reflash it, right?
Old 04-10-2021, 04:50 AM   #9
tomm.brz
flash stock with ecutek with a jdm calid that you know HKS supports in their flash system
When a stock rom is flashed , ecu is unlocked then you just can flash once with the hks system and it will flash and overwrite the ecutek licence forever
Old 04-11-2021, 05:25 AM   #10
steve99
I think you should jist stay eith ecutek
you already have licience in ecu which will be wasted if you go hks flash editor
you wont be able to extract hks editpr tunes and i suspect they will be for japanese fuel and likely not particularly suited to your fuel
You would be better staying with ecutek and use its usefull features such as full time closed loop fuel control and speed density
those features not available on hks
you could also have say a 95 and 98 map using ecutek map switching even if your not using flex fuel option
you can get a better result with an ecutek remote tune likely cheaper than buy hks editor and tunes
The Following 4 Users Say Thank You to steve99 For This Useful Post:
gpvecchi (04-11-2021), saltywetman (04-12-2021), Thefalls (04-14-2021), tomm.brz (04-14-2021)
Old 04-11-2021, 08:14 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
As Steve said ^^^^^^
It is not a good idea to switch to the HKS editor. A really waste of money. They have much better fuel quality in Japan and the tune won't be optimal with the fuel we have in Europe. Additionally, you'll lose all the extra features of Ecutek.
Old 04-11-2021, 10:23 AM   #12
gpvecchi
gpvecchi's Avatar
Thanks, fuel should not be an issue, premium fuel in Japan is at least 96 octanes, while in Italy we have 95 and 100 (I always use 100, for EU calibrations at least 98 octanes is needed).
I'm actually using ZA1JU01A stock JDM calibration and it works perfectly.
I'm not happy with Ecutek, they have very inconsistent support, it's overpriced, it has a lot of features, but many of them useless for a NA street car.
It's invasive for the ECU, most master tuners in Europe are really dumb, they are just sellers; in fact, Ecutek in Japan is practically unknown.
Do you know if Flash Editor can be updated? I need version 2.29.
Old 04-11-2021, 11:05 AM   #13
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Hate to break it to you, but HKS support is bad also.
Not sure why you don't just remote tune like everyone else does.
You already paid for all the "useless for N/A" stuff. (Not sre what that even means)
You are not getting any significant money back if you even sell the cable.
The license is tied to the ECU and you cant untie it.
But hey, it's your money to burn.
Personally (after looking through all your other threads) I'd stop drinking so much of the JDM4LYFE Kool-Aid.
Just because it's JDM does not make it better.
gpvecchi Do you have this sticker on your car?
Old 04-11-2021, 11:30 AM   #14
tomm.brz
i don't think it's overpriced, it's very unique and a powerfull tool, custom maps are amazing to have
The support is one of the greatest support I ever encountered actually... they haven't learnt yet how to upload correctly all the stock tunes for the retail people like us but if you make a mess while flashing, with ecutek you fix it very easily, and if you don't they help you very quickly
If it's useless for you and you want a basic logic tune without any extra because your car is NA and you do not need them, it's not the product that is faulty
HKS tunes are rich and have stupid ignition timing and they modify cam timing only on Open loop pulls, because you know , it's easy to do a quick safe tune on a dyno in few time...
the rest of the tune, the closed loop zone) it's basically stock
And they are OTS tune, exactly like stock and openflash tunes
OFF THE SHELF is a compromise, a tune that must function acceptably in EVERY gt86 of the world, in any climate
With ecutek you buy a kit that is HIGHLY resellable (the HKS only JDM fanboys will buy it, if you find someone paying for that OVERPRICED instrument...)
You custom tune you car perfectly for you usual fuel and average weather condition, if the tuner keeps your tune unlocked you could even do small modifications
You can set failsafe against any thing comes in your mind that comes from a sensor,
You have different timing tables and maps for different fuel (since you re in italy, try ENI 100 ron and WR100 and look at the logs for AFR and knocks.. same octane rating, but different quality and combustion speed will make a noticeable difference)
You can find many good purpose for the extras and the custom maps even for NA street cars
Any shower experts here? Roy68 Off-Topic Lounge [WARNING: NO POLITICS] 69 07-23-2019 12:08 PM
Collision experts and body repair experts :) Mikeez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 03-17-2015 12:58 PM
Need help from some experts tiz22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-18-2014 11:05 PM
need an frs experts help please! kseriescivic Engine, Exhaust, Transmission 16 08-10-2013 09:54 AM
Drivetrain experts! Name this car! :) aspera Engine, Exhaust, Transmission 200 08-16-2010 12:41 AM
