Old 04-08-2021, 08:42 PM   #1
Nitemare15
Drives: 2015 Scion FR-S
Replacing valve cover gaskets
Hey guys,
I have a 2015 Scion FRS pushing right under 90k miles. I'm the third owner.
I just found out that my right side valve cover is leaking oil and dripping onto my exhaust. While I'm in there, I'm going to do the spark plugs, both valve cover gaskets and I'm not sure if there is anything else I should look into engine wise.
I am also most likely going to buy a used transmission because I've started having issues with 4, 5 and 6 gears (synchros I think, there were issues when I bought the car, but they have gotten considerably worse). I bought a short throw shifter a while back, so while I am in there I was going to change out the shifter, shift springs, clutch fork, clutch fork pivot, shift spring and TOB. Is there anything else that I should look into?
Any help will be GREATLY appreciated
Nitemare15 is offline   Reply With Quote
Old 04-08-2021, 10:12 PM   #2
humfrz
Originally Posted by Nitemare15 View Post
Hey guys,
Hi ya, Nitemare15 -
While you are in there, you might consider replacing the clutch and pressure plate -
Old 04-08-2021, 10:22 PM   #3
Nitemare15
Hi ya, Nitemare15 -
Hey there humfrz 😄 the clutch was changed about 2 years ago right before I bought the car from the previous owner! I do plan on eventually supercharging it but that's a few years down the line. I figured I'd do the clutch upgrade then, thoughts?
Old 04-08-2021, 11:50 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I agree with @humfrz, but with the additional recommendation of a heavier-duty clutch NOW while you have it all apart, since you're boosting later on down the line. This simply saves you time and work in the long run. It will not affect the performance of the engine or transmission now, but you'll be all set and ready to go after you've installed the supercharger.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 04-09-2021, 12:22 AM   #5
Nitemare15
Okay, that makes perfect sense. Is there a specific clutch kit that you guys would recommend?
Old 04-09-2021, 05:56 AM   #6
I don't have one to recommend but will say that you should probably stay away from the ACT clutch. There have been many, many issues reported with them on here. Of course some were fine as well but the weight of evidence says there are more issues than not.
Old 04-09-2021, 11:28 AM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Aftermarket clutch reviews:
https://www.ft86club.com/forums/showthread.php?t=112791
Old 04-09-2021, 07:01 PM   #8
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Hey guys,
Try fluid before you go buy a used tranny. I run Redline in my tranny and have zero issues. Good luck.
scion fr-s is offline   Reply With Quote
Old 04-10-2021, 05:35 PM   #9
Nitemare15
That was my FIRST go to 😭😭😭 I've changed the fluid twice now and the problem has only gotten worse ☹️
Old 04-10-2021, 05:39 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Gosh, the OP is brave, supercharging an engine nearing 100k miles..
Old 04-10-2021, 06:23 PM   #11
humfrz
pssssttttt - small boost, compared to back in the day.
Old 04-11-2021, 08:07 PM   #12
Nitemare15
Haha yup, it's going to be low boost for sure. I'm not looking to make 350whp or anything �� And I'll check compression and leaks prior to SC �� If it blows, it blows lmao
Old 04-11-2021, 08:29 PM   #13
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Make sure your clutch pedal is adjusted properly. Some will adjust the height which can cause shift issues when done incorrectly.
Old 04-14-2021, 04:13 PM   #14
chipmunk
Drives: _
just make sure that your TOB is the most updated part #. Also use the correct spec lube for that TOB
chipmunk is offline   Reply With Quote
Valve Cover Gaskets VoltsFRS2013 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 12-24-2021 03:33 PM
Replacing Valve Core Spuds Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-29-2018 04:54 AM
Other Oil leaks - Oil Pan gasket? - NOT Cam plate, valve cover, or Cam cover exE36M3 Issues | Warranty | Recalls / TSB 17 11-08-2017 10:15 AM
Changing Spoiler Without Replacing Trunk. Cover or Plug Holes? ajcarson11 Cosmetic Modification (Interior/Exterior/Lighting) 2 09-25-2015 07:12 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
