Old 01-24-2018, 11:19 PM   #1
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Replacing Valve Core
Anyone replace a valve core in the stock wheels? One of mine got messed up a while ago and now likes to leak.
Anyway, it seems like a really simple procedure so I am going to try my hand at it this weekend (never needed to bother with it before). Just making sure there isn't anything special about the twins tpms stems I need to know.
Also, any advice or gotchas would be appreciated.
Old 01-25-2018, 04:20 PM   #2
toast
Drives: 14 BSP Edelbrock BRZ
It is just a schraeder valve. If you've taken the valve stem out of a bicycle before you've done it already.
toast is offline   Reply With Quote
Old 01-25-2018, 04:37 PM   #3
ls1ac
ls1ac's Avatar
If you are lucky it is just the valve core and a replacement can be had at any parts store or even Walmart. A removal tool is good to have anyway and it too can be had as above. If it is the stem that is bad then a whole new TPS valve is needed and requires removing the tire, replacing and reprograming.
Old 01-25-2018, 05:16 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If you have a friendly relationship with your tire shop; they probably would just give you one. (or do it for you for free)
My tire shop would.
I LIKE TIRES!
Old 01-25-2018, 06:43 PM   #5
Spuds
The Dictater
Spuds's Avatar
My tire shop would.
'My tire shop' stripped 3 lugs last time I was there. Not going back. Note to self, get new tire shop.
Old 01-25-2018, 06:50 PM   #6
Spuds
The Dictater
Spuds's Avatar
I'm 99 percent sure it's just the core. Already got the tool and valves, hoping that there wasn't anything special that I was missing. Damn these thing are cheap lol. I love universal parts.
Stem is fine on the outside. Somehow the pin inside got bent. Hoping the bent pin is the whole of the problem.
Old 01-25-2018, 06:52 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Ouch! That sucks! Sorry to hear that. I just replaced all of my lugs. It was pretty easy with a ball joint separator.
I LIKE TIRES!
Old 01-25-2018, 06:55 PM   #8
Spuds
The Dictater
Spuds's Avatar
Lol I used a HF ball joint separator myself. Super useful tool. Also can be used as a swager with some scrap metal as backing.
Howd you manage the rears? That one was a PITA with the brake shoes on. Did you just remove them?
Old 01-25-2018, 07:01 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, I was replacing pads and rotors, so had them off. Made installing the lugs easier.
I LIKE TIRES!
Old 01-29-2018, 12:37 AM   #10
Spuds
The Dictater
Spuds's Avatar
Just to close this out in case it comes up in someone's search, I replaced the valve using the following procedure with no issues. I'm sure some steps can be skipped. I used one of the screwdriver type valve replacement tools (not the 4 in 1) and a generic schrader valve.
1. Jack up the corner in question.
2. Let out air from tire.
3. Use tool to unscrew valve from stem.
4. Screw new valve in.
5. Inflate tire
6. Lower car
7. Come back in an hour to check pressure.
Old 01-29-2018, 04:54 AM   #11
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
If you're quick you don't even have to jack it up or anything. Take the old one out, quickly shove the new one in. Top off with air.
Setrab Series 9 : 15 row oil cooler core byun Engine, Exhaust, Bolt-Ons 3 12-05-2016 02:19 PM
heater core leak dragonwiddd Issues | Warranty | Recalls / TSB 2 05-15-2014 10:10 PM
WTB: powder coat caliper core? jeffs42885 Brakes, Suspension, Chassis 2 09-15-2013 08:34 PM
WTB Core/Full Motors Dustin@Dynosty Engine, Exhaust, Bolt-Ons 2 07-07-2013 01:36 AM
