Drives: 2015 FR-S
Nasty shimmy; what do?
So I got my fucked up wheel fixed (it got a dent from hitting debris in the road from an accident in front of me I was very lucky to not be a part of) and hoped this would have gone away but it hasn't. At about 90-95 I get a wicked shimmy starting up. The wheel has some weights in it and wasn't rebalanced after the repair, would that be enough to do it or should I look for suspension damage? If I had a decent jack and some stands I'd go take some pics but I don't at the moment. It's on the to-do list, as I got a easy to work on car on purpose so I could learn, but unexpected expenses happen so it got pushed back.
ProCrastinationConsultant
I would first rotate the tires front to back to make sure the problem follows the wheel(in case it's something to do with the axle or wheel bearing).
As long as it's just the wheel, then get it rebalanced,though I would assume rebalancing would be typical of a wheel repair...
| The Following User Says Thank You to soundman98 For This Useful Post: | x808drifter (04-04-2021) |
Drives: Subaru BRZ
Did you remove the plastic protective coverings before the using the 'fucked up' and now repaired wheel?
Drives: 17 Asphalt 86
I would start with a rebalance and check the alignment if the issue persists.
It's worth checking the alignment if you haven't in a while. |
Drives: hyper blue
the car comes with a scissor jack. raise the offending wheel/rim and rotate it to check the runout.
if it wobbles, replace the rim. |
Drives: 2016 Scion FRS Release Series 2#439
You may have a damaged tire.
| Front seat bolts look nasty | Ernest72 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 09-19-2019 07:36 PM |
| Nasty curb scrape | Spacemane969 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 11-03-2018 12:00 PM |
| Nasty Enginer Noise - Help needed | elchote | Issues | Warranty | Recalls / TSB | 22 | 01-22-2016 10:06 PM |
| Very nasty grinding on fast corner exit from LSD? | JaguarXJ6 | BRZ First-Gen (2012+) — General Topics | 10 | 12-07-2013 03:06 PM |
| The Nasty FR-S Review Part 2 | Dezoris | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 02-09-2013 10:10 PM |
