Drives: 2018 toyota 86
ECU Not Recognized After ECUTEK flash fail
Hi all,
I just installed a new turbo kit on my 2018 toyota 86, and was in the process of tuning it with ECUTEK. My Tuner sent me a rom file to install but in the middle of the process the cable slipped out of the PC and the tune failed to finish installing. Now the ECU is not detected by proEcu anymore and even when I manually pick the car, when I query the ECU or try to install the rom again, it gives an alert saying "This appears to be a part programmed ECU" and then fails saying the vin numbers don't match but it's not acutally reading the cars vin number. It's also showing unknown ECU Version Cal.id = ÿÿÿÿÿÿÿÿ. I've tried pulling the battery for a while and retrying it but no luck. I've already tried to take the battery out for 30 ish minutes and try again, still shows unknown ecu id and says vin() doesnt match the one on rom which is (JF1......) any help would be appreciated Last edited by __blank__; 04-03-2021 at 07:08 PM. Reason: Added What has been tried |
#2 | |
If you have already followed the ecutek recovery proceedure here https://ecutek.zendesk.com/hc/en-gb/...8-ECU-Recovery ie manually selected ecu type then flash a stock rom of correct calid then you will need to contact ecutek directly in England they will try remote recovery or you may need to send them ecu |
Ok
vin is not like ZA1JN10C thats the ecu calid if the ecu flash failed the calid eill be rubvish or not there so dont worry Dont try to read ecu or do query ecu on a part programmed ecu you jist get rubbish amd failures Do as in the ecutek recovery Remve battery terminal replace terminal Then Turn ignition on and do the recovery straight away dont try and start car do do query ecu Manually select vehicle type and ecu type select a stock om of correct ecu calid and then flash it you may need to get tuner or ecutek to re issue flash points as you likely lost ecutek licience in ecu |
#4 | |
I did everything they said, issue is when I select manual and do it, it still says VIN does not match the one on the ROM and shows the VIN as an empty string. I have contacted them, they're closed over the weekend, hopefully Monday I can get up and running |
#5 | |
Thank you, I did remove the battery and try to do so, but it gives me the following message, it like does not even let me flash it to the previous ROM. Where can I find the stock one, that might help, because ECUTEK shows the stock tunes only if it sees the VIN numbero or the Cal.Id which for mine it shows neither. It only shows the following message |
Ecutek comes with all stock roms in directory C:/ecutek/,proecuRom files
looks like your going to need to get ecutek in UK to look at that , they are very good and eill remote into your computer, Just open a case with them |
Thank you so much, I have sent them an email on Friday. Will give an update as soon as I get one
#8 | |
Try flashing a stock ZA1JN10C rom instead of the turbo tune then if that flashes ok try the turbo tune again looks like tuner has keyed turbo rom to you cars vin the wtock rom wint beckeyed to vin |
| The Following User Says Thank You to steve99 For This Useful Post: | mrderp (04-06-2021) |
Just an update on this.
Thank you again @steve99 for all your help. Following your recommendation, I tried flashing the stock rom on the car but it seems like ECU wiped my license so after the weekend, I contacted the tuners, they corrected the issue and added some flash points onto the dongle. I was able to flash the stock then the customized one and was able to get the car fully tuned yesterday. Just a little tip for everyone, when flashing, be VERY careful not to unplug or move the cable and don't touch anything in the car while it's being flashed. It's not worth the time and frustration to fix it. |
| Tags |
| ecu, ecutek, problem, tune, tune issue |
| water / meth kit fail-safe with ecutek | 86TOYO2k17 | Forced Induction | 2 | 02-28-2019 09:37 PM |
| Regular Key Not Recognized | 3nl | Issues | Warranty | Recalls / TSB | 13 | 08-26-2017 12:34 PM |
| [OFT] Original calibration not recognized | nastynate88 | Software Tuning | 6 | 04-11-2016 09:21 AM |
| Ecutek flash & warranty | 3000HP | Software Tuning | 40 | 04-06-2015 10:33 AM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
