Old 04-03-2021, 12:46 PM   #1
Bmertens
Drives: Murdered 2015 Frs
Unhappy Dead frs !!!!
Hello ! I drive a standard 2015 frs and have just recently installed a new k&n cold air intake. I finished the install and everything is put together, but the car won’t start!!!! it just goes into auxiliary with no climate control and the center console doesn’t come on. I’ve checked the battery, and fuses for anything wrong but they are completely fine. Anyone got any ideas on how i can get it started ?
Bmertens is offline   Reply With Quote
Old 04-03-2021, 12:51 PM   #2
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Manual transmission or automatic?
EDIT: My bad, I see standard.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 04-03-2021, 12:55 PM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Any other modifications made to the car? You should list them all to give us an idea on where to start troubleshooting.
Old 04-03-2021, 01:05 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
how did you check the battery? what voltage is it at? did you check the fuses on top of the battery?
humfrz (04-03-2021)
Old 04-03-2021, 01:32 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Choke a car, it'll die.. did you take off the protective K&N packaging before installing?
The Following 3 Users Say Thank You to JD001 For This Useful Post:
DarkPira7e (04-03-2021), jcw99 (04-03-2021), soundman98 (04-03-2021)
Old 04-03-2021, 01:47 PM   #6
Bmertens
The car is bone stock otherwise, first mod for the car
Old 04-03-2021, 01:56 PM   #7
Bmertens
Well not to sound like a scrub I jumped the car off because the battery did die after i put the intake. No clue what voltage it’s at and the fuses are definitely working correctly I would think because the car has auxiliary power.
Old 04-03-2021, 02:55 PM   #8
The "auxiliaries" can work on 4 to 10 volts. the car will not start on that. Do a proper check of your battery.
humfrz (04-03-2021)
Old 04-03-2021, 03:47 PM   #9
Grady
Grady's Avatar
What did you do? Pull the engine to put the filter in?
The Following User Says Thank You to Grady For This Useful Post:
JD001 (04-03-2021)
Old 04-03-2021, 04:04 PM   #10
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Is the car cranking or not? If not, or there is just an audible click but no cranking, check your battery.
Old 04-03-2021, 04:40 PM   #11
BigHugeFatGuy
BigHugeFatGuy's Avatar
Drives: 2016 FRS
Any issues before the intake? It's not the issue IMO, as you can start the car with the intake entirely off....
BigHugeFatGuy is offline   Reply With Quote
The Following 2 Users Say Thank You to BigHugeFatGuy For This Useful Post:
BrahmaBull1990 (04-04-2021), soundman98 (04-03-2021)
Old 04-03-2021, 04:41 PM   #12
Bmertens
The starter won’t click as if the battery were dead when i turn the key. About to check how many volts the battery is putting out now
The Following 2 Users Say Thank You to Bmertens For This Useful Post:
DarkPira7e (04-05-2021), KR-S (04-03-2021)
Old 04-03-2021, 11:37 PM   #13
milanojess
milanojess's Avatar
Drives: 2013 FRS
If just jumped, it’s not charged yet
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 04-05-2021, 12:37 PM   #14
Well?
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 04:17 PM
(S)he's dead, Jim. D.Scrye Scion FR-S / Toyota 86 GT86 General Forum 37 02-11-2016 03:40 PM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 04:06 PM
The Walking Dead RAP ThreeZzZ Off-Topic Lounge [WARNING: NO POLITICS] 1 01-12-2015 05:43 PM
