Drives: Murdered 2015 Frs
Hello ! I drive a standard 2015 frs and have just recently installed a new k&n cold air intake. I finished the install and everything is put together, but the car won’t start!!!! it just goes into auxiliary with no climate control and the center console doesn’t come on. I’ve checked the battery, and fuses for anything wrong but they are completely fine. Anyone got any ideas on how i can get it started ?
#2 | |
Master Collaborator
Manual transmission or automatic? EDIT: My bad, I see standard. |
#3 |
Master Collaborator
Any other modifications made to the car? You should list them all to give us an idea on where to start troubleshooting.
#4 |
ProCrastinationConsultant
how did you check the battery? what voltage is it at? did you check the fuses on top of the battery?
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (04-03-2021) |
#5 |
Drives: Subaru BRZ
Choke a car, it'll die.. did you take off the protective K&N packaging before installing?
| The Following 3 Users Say Thank You to JD001 For This Useful Post: |
#6 |
#7 |
Well not to sound like a scrub I jumped the car off because the battery did die after i put the intake. No clue what voltage it’s at and the fuses are definitely working correctly I would think because the car has auxiliary power.
#8 |
The "auxiliaries" can work on 4 to 10 volts. the car will not start on that. Do a proper check of your battery.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (04-03-2021) |
#9 |
What did you do? Pull the engine to put the filter in?
| The Following User Says Thank You to Grady For This Useful Post: | JD001 (04-03-2021) |
#10 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
Is the car cranking or not? If not, or there is just an audible click but no cranking, check your battery.
#11 |
Drives: 2016 FRS
Any issues before the intake? It's not the issue IMO, as you can start the car with the intake entirely off....
| The Following 2 Users Say Thank You to BigHugeFatGuy For This Useful Post: | BrahmaBull1990 (04-04-2021), soundman98 (04-03-2021) |
#12 |
| The Following 2 Users Say Thank You to Bmertens For This Useful Post: | DarkPira7e (04-05-2021), KR-S (04-03-2021) |
#14 |
Well?
| Dead battery | technoid | BRZ First-Gen (2012+) — General Topics | 17 | 03-17-2016 04:17 PM |
| (S)he's dead, Jim. | D.Scrye | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 02-11-2016 03:40 PM |
| Dead battery!?! | Hoahao | Issues | Warranty | Recalls / TSB | 5 | 02-23-2015 04:06 PM |
| The Walking Dead RAP | ThreeZzZ | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-12-2015 05:43 PM |
