Drives: 2013 Supercharged BRZ, E85, Ohlins
Diff build
Finally got all the time, money and parts to get the rear diff properly upgraded.
My 2013 BRZ came with a 4.1:1 final ratio, whereas the 2019 BRZ comes with a 4.3:1 final ratio. I sourced a new 4.44 ring & pinion (shout out to JacksTransmissions.com) coupled with a Quaife ATB Automatic Torque Biasing differential. This equates to about an 8% rise in RPMs for a give highway speed, over stock. I had the idea to buy a used, empty diff carrier and clean it up, then take all the parts to a performance builder near me who has all the shims and indicators and gak to ass-emble a new rear end. When the new pumpkin was ready, we swapped it in. Works like a charm! . . . . . . Extra capacity finned diff cover sourced from Harrop USA. ----------------- Driving notes: Noticeably different torque management esp. in the wet. Better acceleration and less delay for lockup/transfer under hard cornering. Still managed 28 mpg on a 6th gear hw cruise recently. |
| The Following User Says Thank You to canyons For This Useful Post: | jcw99 (03-27-2021) |
LMGTFY
Drives: 13 FRS, 91 Miata
What was the reason for swapping the factory torsen LSD for another geared aftermarket one?
Far as I can tell they both do the same thing and act the same way. |
| The Following User Says Thank You to x808drifter For This Useful Post: | jcw99 (03-27-2021) |
Drives: 2017 toyota 86
Pretty sure factory LSD is basically an open diff if only one wheel lifts or loses traction.
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | DarkPira7e (03-27-2021) |
#4 | |
ProCrastinationConsultant
every other vehicle just unloads the inside tire to a smeary smoky 1 in the same spots. so not sure what this is about...
Rust bucket enthusiast
It's a different story when there's no resistance on the tires, vs pavement that provides resistance
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#6 | |
did you get the hovercar conversion?
Ice, snow. A torsen isn't anything like a clutch type diff in the snow or on ice
| The Following User Says Thank You to DarkPira7e For This Useful Post: | soundman98 (03-27-2021) |
Persona Non Grata
Drives: '15 BRZ (WRB)
Or wet grass. No kidding. I've gotten stuck on wet grass.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | soundman98 (03-27-2021) |
LMGTFY
#10 |
Drives: Crapcan
Diff build
Torsen diffs are torque sensing. Until it feels a difference in torque from each wheel it is an open diff. It is also an open diff if there is zero load on one wheel. I don’t know how sensitive they are but it’s possible that extremely low traction surfaces may not put enough load to immediately engage it. Ive gotten stuck on grass before, you can slowly pull your parking brake and sometimes get it to engage both sides in this situation.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#11 | |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Wally86 (03-29-2021) |
#12 |
Drives: 2014 GT86
As torsen needs some traction even to wheel with least grip, to be able to multiply torque to it to other, so when one wheel completely looses traction, it's almost acting as if open diff. Be it due wheel hop in air after kerb, ice or wet grass.
Normally during DD it's supposed to be fixed/complemented by electronic nannies that apply brakes individually to wheel, that lost traction. Hence sometimes it's worth to NOT switch all nannies off on regular basis at all driving patterns, to have e-diff to help with mechanical specifics/limitations of torsen type diffs. Do clutch type diffs provide more grip in wider range of scenarios? Yes. But they are also noisier and require more maintenance, so no wonder that manufacturers usually prefer torsen to clutch type diffs, as most cars (including ours) are mostly driven only on public roads, and with electronic nannies left on. |
| The Following User Says Thank You to churchx For This Useful Post: | NoHaveMSG (03-28-2021) |
#13 |
Señor Member
OP hasn't been online since he posted. I would be curious to know if he has noticed any difference with the LSD. I know that there can be differences in the gear type of LSDs, such as the torque multiplier and even some with a tiny plated setup in the middle for exactly those situations where one wheel is in the air.
To my mind the cost benefit ratio isn't there to go from the OEM gear type LSD to and aftermarket one but I could be wrong
1974 TA22 Celica
2013 86 GT |
| The Following 2 Users Say Thank You to Turdinator For This Useful Post: | NoHaveMSG (03-28-2021), x808drifter (03-29-2021) |
#14 | |
Drives: Crapcan
That’s my thought too. I don’t think any aftermarket LSD’s prevent spinning up a tire if it’s in the air which is the only thing I’d like improved. At my driving level anyway. Sent from my iPhone using Tapatalk
| Tags |
| diff, gears |
| Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 11:23 AM |
| Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? | mistople | Engine, Exhaust, Transmission | 10 | 09-21-2018 07:01 PM |
| HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions | Corradooo | Engine, Exhaust, Transmission | 2 | 11-25-2017 08:16 PM |
| Diff Mount Inserts install - Diff won't lower??? | ChRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-17-2017 01:07 AM |
| Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 03:59 PM |
