Old 03-26-2021, 02:26 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Oil pressure
Before I start up my new rebuilt engine i was trying to get oil pressure going but im not getting any oil pressure the oil filter is dry i might be thinking it wrong but i dont wanna burn my starter out so any suggestion it has about 7 qts of break in oil
IsaiahW is offline   Reply With Quote
Old 03-26-2021, 02:29 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
How long did you crank it? Make certain you're cranking the car with the gas pedal held at 100%
You're definitely not going to burn out your starter that easily
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 03-26-2021, 02:31 PM   #3
IsaiahW
IsaiahW's Avatar
Oil pressure
Not very long my concern was the starter so should i just continue cranking?
Old 03-26-2021, 02:43 PM   #4
DarkPira7e
DarkPira7e's Avatar
Yeah the starter isn't going anywhere. Should only take 10-15 seconds of cranking to see some oil pressure.
Old 03-26-2021, 02:59 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
10 secs on -> 3 mins cool-down -> ...
Old 03-26-2021, 03:15 PM   #6
IsaiahW
IsaiahW's Avatar
Imma try and take the spark plugs out because ive been cranking for a minute still no pressure i had pressure when the engine was on stand while checking compression but had to remove oil to put in break in oil i have a oil cooler so refilling oil on stand will just have the oil coming out oil ports that connects to cooler
Old 03-26-2021, 06:05 PM   #7
IsaiahW
IsaiahW's Avatar
Just a update i had a air pocket in oil cooler so disconnected lines cranked til i see oil coming out ports then reconnected, cranked again now i have pressure
The Following 7 Users Say Thank You to IsaiahW For This Useful Post:
BrahmaBull1990 (03-27-2021), DarkPira7e (03-26-2021), Dzmitry (03-29-2021), jcw99 (03-27-2021), NoHaveMSG (03-26-2021), soundman98 (03-26-2021), Ultramaroon (03-26-2021)
Low Oil Pressure? kimcheefists Issues | Warranty | Recalls / TSB 10 07-17-2023 03:37 AM
Oil Pressure drz400dude Engine, Exhaust, Transmission 9 04-30-2019 10:32 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
