Old 03-26-2021, 11:34 AM   #1
pro_turbo
Drives:
Rom Raider logger help
Anyone can teach me simple which def i have to use on my 2013 AT toyota 86 ?
And how to use it on rr
Also with dyno def please
Thanks.
pro_turbo is offline   Reply With Quote
Old 03-26-2021, 07:41 PM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
Thanks.
1- Are you using an OpenFlash OTS tune? In that case it's ZA1JA01I (but you need to edit it to match your tune).
If not, we need more info.
2- For using it in RomRaider, open RomRaider, go to Definition manager, add definition, select correct definition, press "Save" and "apply"
3- I have no idea what you mean with "dyno def"
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 03-27-2021, 02:26 AM   #3
pro_turbo
Drives:
i am using rom raider sir
and i did put the def with the correct car def which is 01I but i have several other def inside the def manager
should i remove all the other first
dyno definition to use with the rom raider logger dyno
Old 03-27-2021, 07:47 AM   #4
steve99
romraider lggger amd the virtual romraidercdyno has never been configured for brz\86
jist other subaru like wrx forrester
Old 03-27-2021, 09:32 AM   #5
pro_turbo
Drives:
Aaahh thats make sense.
So the only thing i can use is the logger with the taxtric ?
How can we add some more data to record in therre
Old 03-27-2021, 12:25 PM   #6
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
It depends..
It has to have had memory addresses added in order for it to record there. I know there was a thread that had the memory addresses and how to modify the logger to log those addresses, but I don't remember what it was called.
Jaden
Jaden is offline   Reply With Quote
Old 03-28-2021, 10:48 PM   #7
pro_turbo
Drives:
Jaden
Thanks jaden. I will try to find
OFT or ROM-Raider? stevesnj Software Tuning 2 04-29-2017 07:35 PM
Customizing the torque curve using ROM Raider illmatic_frs Software Tuning 8 02-15-2016 01:12 AM
Help w/ OFT and Rom Raider Cooperdh Northwest 5 09-20-2015 05:21 PM
Misihimoto Intake Tables for Rom Raider efactor84 Software Tuning 7 08-07-2015 05:39 PM
FS: 2010 Yamaha Raider S pche NY / NJ / CT / PA 1 12-15-2014 09:01 PM
