Drives: 2015 Scion FR-S
Anyone have tables I could use to dial my trims for the Mishimoto Intake? I got a CEL for p2097 and p219a.Both CEL pretains to fuel trim rich and afr imbalance. I'm running OFT and OFH Stage 2 UEL tune and I currently use 93oct. Thanks.
#2 | |
think you may have other issues like intake/exhaust leaks, or dirty maf sensor ect. |
#3 | |
Update: Now I'm seeing my LTFT jumping +10-14 when I hit the gas in close loop. I switched tunes and same result. So its obvious I have a leak or something loose somewhere. Keep you all updated. I'm going to inspect tomorrow to see if there are any leaks using the cloth and soap/water method. Last edited by efactor84; 08-01-2015 at 07:36 PM. |
| The Following User Says Thank You to efactor84 For This Useful Post: | Frishkorn (08-05-2015) |
The front o2 sensor was loose. I've checked under to see if there were any leaky gaskets. I didn't find any leaks, when I was using the soap/water method or unusual noise. My fuel trims were between -.78 to +3.24. Later, I found the rattle noise coming from both the o2 sensor's rings. This helped answer my question and hope this will help others, who experience this.
| The Following User Says Thank You to efactor84 For This Useful Post: | steve99 (08-02-2015) |
Hi everybody!
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
I had no such issues with mine. Which begs the question, is it the new style Mishimoto Intake?
No, it's the one that requries to remove your bumper; it would look like Perrin's setup. My trims came down between +8 and +14 everytime I hit the gas. That's when I found my main issue was just a loose o2 sensor causing my afr to be imbalance and running rich.
| The Following User Says Thank You to efactor84 For This Useful Post: | Frishkorn (08-07-2015) |
Hi everybody!
Thank you, was just curious. I too have the original remove the bumper option. Sure it's a pain the ass to remove a bumper for an air filter but seems like I'm always taking it off and putting it on anyway.
My trims so far, since the fix hasn't changed. I don't know if I need to do any adjustments. My LTFT is at +1.56 to -.78, sometimes it will be at +3.98 when I accelerate and it corrects itself to +1.56. I haven't done any tuning yet and I don't think I need to. I'm happy its running the way it should. My fuel mileage went up by 20 miles more before I hit the halfway mark at 140mi instead of 120mi. I'm continuing using Shell 93OCT, which seems to help calm down the cricket noise; its not eliminated completely. The rough idles hardly hit that many times like before, maybe once in a blue moon I might get it during the week.
| OFT E85 Tune w/ Modifed MAF tables | SpeedFromSwede | Software Tuning | 2 | 02-18-2015 09:25 AM |
| FS: 2010 Yamaha Raider S | pche | NY / NJ / CT / PA | 1 | 12-15-2014 09:01 PM |
| Coffee Tables? | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 10-20-2014 03:51 PM |
| Comparing OpenFlash, EcuTek, Rom Raider & Tuner Studio. | Cross | Software Tuning | 25 | 02-10-2014 04:36 PM |
