Old 03-26-2021, 02:36 AM   #1
terryhines
Drives: red
A little question
DeWALT DW089LG: Why You Should Buy It?
What could be better than meticulous attention to detail? If you're a designer who wants to build a particular project and get the most significant outcomes for construction projects that demand precision, this review is for you. This post is about the DeWalt DW089LG, considered the best laser level for builders, and will show you all its features and capabilities.
#1 - Design Components:
When you first encounter this cross line laser level, you might assume it's a huge undertaking. Its dimensions are, in fact, more extensive and heavier than those of competitors. On three of its sides, aluminum windows for pendulums have been placed. They project three green lines on the walls and ceiling, which cross at a specific location.
It has the appearance of a black cube with orange insertions. Plastic, metal, and glass are the components used to create this contraption. This combination protects the level from water, which is crucial while using it outside and damage if it is dropped.
#2 - Benefits & Special features:
Superior Capabilities for Full Room Layout:
The capacity to emit three brilliant laser lines at 360 degrees regularly is the most crucial feature that makes this laser level outstanding. If you do a lot of layout and alignment work regularly, you'll appreciate this laser-level tool's adaptability and clear reference lines.
When the tool is turned on, it produces three 360-degree planes, one vertical and two horizontal lines that are 90 degrees apart. This function is excellent for quickly setting up a layout from a single starting point.
Excellent visibility:
The DeWALT DW089LG level emits strong green laser lines four times brighter than radiating red laser lines.
These laser lines have an operating range of up to 100 feet and an accuracy of 1/8 at 30 feet, giving users a wide range of options for indoor and outdoor applications.
Furthermore, this top cross line laser level includes an inbuilt pulse mode that allows you to quickly couple the laser level with a receiver for line detection, full laser brightness, and increased working range.
Mounting Options:
The incorporated magnetic bracket on the DeWALT best cross line laser allows users to attach the instrument to most metal surfaces, such as metal tracks, brackets, or frames.
This bracket can revolve 360 degrees on its mount for the best placement on multiple surfaces simultaneously. The tool also has a standard 14-inch and 5/8-inch thread for tripod and other brackets, letting you install it in various ways.
Durability and Usability:
As previously said, the manufacturer has meticulously analyzed every feature at this level. As a consequence, a device that works perfectly and can be used for a long time appeared.
The materials meet the IP65 standard, which means they can withstand a wide range of situations while protecting the inside cross line laser from harm and water. It's like a plane in the sky that never gives up in the face of adversity.
#3 - Drawbacks:
The DeWALT DW089LG is a behemoth compared to other laser levels, despite its adaptability and powerful laser beams. It's also more expensive, putting it out of reach for do-it-yourselfers and homeowners on a budget.
#4 - Wrap Up:
For ideal outcomes, it's time to rely on this best laser level for the money. You could be perplexed as a newcomer after seeing so many laser levels on the market. You may end up with the wrong type. You can now choose any model for long-distance work, and beams will appear.
terryhines is offline   Reply With Quote
Old 03-26-2021, 06:34 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Depends on the RPM.
Old 03-26-2021, 08:21 AM   #3
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
If this is your first BRZ/86, it does take a bit to get used to the transmission. I went from a Mazda 3 to this, took me a while to make smooth gear changes and having vehicle jerking in between.
Old 03-26-2021, 08:33 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Mine does this, it's really really annoying. The drivetrain lash in the car is crazy. I'm working on getting rid of as much as mine as I can, once my car runs I can let you know if I was successful.
I've upgraded the motor mounts, transmission mount, strut mounts, struts, differential bushings, subframe bushings, and installed a carbon fiber driveshaft.
Previously, I used solid transmission mounts ( without any other driveline bushings being upgraded) and it removed a great deal of the drivetrain lash. I think the secret is moderately tightening everything up.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 03-26-2021, 08:39 AM   #5
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
1st is the highest gear ratio, so it'll be more torquey than other gears on and off throttle.
BigTuna is offline   Reply With Quote
The Following 3 Users Say Thank You to BigTuna For This Useful Post:
NoHaveMSG (03-26-2021), soundman98 (03-26-2021), The Red One (03-26-2021)
Old 03-26-2021, 10:06 AM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
It's all in the art of driving. Take your foot off the gas, brake or clutch too quickly then you will feel a similar response from the car, jerky and other strange happening.
Move smoothly, the car will respond in the same way. I try to drive in a way that my passengers don't feel any discomfort, even when I am traveling quickly.. it's doing less in the car, don't want to be too busy unless you're a rally driver on rally stage.
The Following 3 Users Say Thank You to JD001 For This Useful Post:
Jdmjunkie (03-26-2021), soundman98 (03-26-2021), Ultramaroon (03-26-2021)
Old 03-26-2021, 10:19 AM   #7
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
All my cars did this in 1st gear.
Just needs a slight bump in the road while in 1st to get the action happening.
Sometimes a clutch action is required to get out of it.
I do find when I leave it in 1st after just starting it becomes more noticeable than when it is properly warmed up.
The Red One is offline   Reply With Quote
Old 03-26-2021, 11:56 AM   #8
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
At low to mid RPM, yes. And if you're unlucky (or a little ham footed) you can get into what people in the aviation community refer to as a PIO (pilot induced oscillation). That is your foot will respond to the "off throttle" jerk by adding gas to smooth it which results in a jerk in the other direction which leads to ... you get the idea.
I think it's best to learn when and how to use the clutch to smooth these things out.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
NoHaveMSG (03-26-2021), Ultramaroon (03-26-2021)
Old 03-26-2021, 12:05 PM   #9
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by terryhines View Post
Hello guys, I have this little query. When the gas was let off in first gear, is it normal for it to be a little jerky? Many thanks.
As some have said, it's normal, and takes practice to master - mostly time. After a couple years now, I still continue to notice my improvement in smooth gear transitions. You can always become a better driver when it comes to an MT.
Dzmitry is offline   Reply With Quote
Old 03-26-2021, 12:14 PM   #10
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Just get out of first as quickly as possible. That'll fix it.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 03-26-2021, 12:16 PM   #11
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
am I missing something here but when were gas pedals in sports cars an on/off switch? very simple answer to OP, if you want to be as smooth as possible, learn to calmly press & release all 3 pedals..
HKz is offline   Reply With Quote
The Following 3 Users Say Thank You to HKz For This Useful Post:
Dzmitry (03-26-2021), JD001 (03-26-2021), soundman98 (03-26-2021)
Old 03-26-2021, 01:19 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Each time I read such threads, I get the same thought, the driving schools are not teaching their students well!!! The cars (unless it has a fault) will drive as it's been driven.. drive it rough, it will respond in the same way..
Old 03-26-2021, 01:23 PM   #13
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
If you're in the States, the driving schools use automatic cars to teach their students. THAT'S the REAL problem.
The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post:
Old 03-26-2021, 01:26 PM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
But you can still learn to drive smoothly.. in UK, if you pass your test in an AT then that is all you can drive, however, if you learn to drive a MT and pass your test in a MT you can drive both..
The Following User Says Thank You to JD001 For This Useful Post:
Dadhawk (03-26-2021)
Alignment Shop in SD and quick question question JohnTran619 Southern California 5 11-21-2018 01:40 PM
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
HID question mrlewistan Cosmetic Modification (Interior/Exterior/Lighting) 8 12-31-2012 07:49 AM
