Drives: 2013 Toyota 86
Overfilled oil after service
So I've just had my oil service done to some guys I knew of being very trustworthy. Enter the FA20, an engine on which they've never really worked on. I picked the car up and drove it around a little bit, parked it, after half an hour decided to check the oil level (I always do, especially after a service) and it seemed quite high for my liking, thought maybe the dipstick was dirty from the oil splashing around. I let the car sit for DAYS on a level parking spot, checked the oil again tonight and lo and behold the oil level is still high. Now I don't have much experience with these types of engines, should I be worried of the crankshaft frothing up the oil?
Here's some pictures of the dipstick from both sides: https://ibb.co/nsYPp73 https://ibb.co/db43Z9S |
Drives: 2015 BRZ
Ideally you want to check the oil when the engine is warmed up and on a flat level ground surface. To me that amount of oil looks normal...
Rust bucket enthusiast
Honestly it looks fine.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| The Following 5 Users Say Thank You to DarkPira7e For This Useful Post: | BrahmaBull1990 (03-26-2021), Dzmitry (03-26-2021), humfrz (03-25-2021), kev0 (03-28-2021), Ultramaroon (03-25-2021) |
The thing is the leftover oil from the 2 lt canister (Motul 300V) is most likely less than half a liter as it is VERY light (0.5-0.6 quarts) and i know the manufacturer states the oil capacity is 5.4L (5.7 quarts) which still worries me.
Again, do these engines run into trouble with a little too much oil in the pan? I also track the car and i wouldn't want the oil splashing around and being agitated by the crankshaft. |
Just the tip
Drives: 2017 DGM BRZ
This style of dipstick is terrible to read accurately.
I'd recommend getting some 120 grit sand paper and sanding a cross hatch pattern onto both sides of the stick. This will help "grab" oil in the right places to give you a more accurate reading. I always check it twice... flipping the dipstick each time so I get a reading on both sides. If you are still concerned, take it back and have them correct it. |
#6 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (03-26-2021) |
Persona Non Grata
Drives: '15 BRZ (WRB)
Looks OK to me. The first image is fine. The second pic looks like some oil ran down the dip stick. The crosshatch on the stick idea is a good one. I will do that soonish.
Slow is smooth, and smooth is fast
not playing cards
Green light go.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (03-26-2021) |
[insert cool phrase here]
Drives: BRZ Premium
Holy cow batman,
Sorry bro, car is totaled. Don’t even bother trying to fix it, just set it on fire and walk away. Jokes aside, I’ll be more worried that they didn’t fill your blinker fluid, nor even asked to fill it. Ok now jokes aside, it’s fine.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#10 | |
I'll be syphoning some oil out as i just don't feel confortable with the amount in the pan currently. Thank you everybody for the inputs. |
#11 | |
I'd be more worried about oil levels being too low and missing the oil pump pickup. |
#12 |
Persona Non Grata
I wouldn't sweat it, but it's your car and your time. Do what you think is right.
#13 |
Drives: 2017 BRZ w/PP
you do realize that when you go up or down a steep hill your oil is going to go way past that level? that is like at most a few ounces over the top dot
#14 | |
You didn't even follow the basic instructions of measuring it when the car has been run and is warm. By letting the car sit for weeks you have let every drop settle into the pan which gives a false high level. Leave it alone. Slightly high is far better than low.
| The Following 6 Users Say Thank You to Tcoat For This Useful Post: | Jdmjunkie (03-26-2021), ls1ac (03-28-2021), Mr.ac (03-29-2021), SCFD (03-28-2021), soundman98 (03-26-2021), Ultramaroon (03-26-2021) |
| Engine Oil Overfilled Causing Leak? | congee | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 07-24-2020 05:25 PM |
| Best service in So Cal.. | Cobaltbloo | Southern California | 5 | 04-23-2018 03:50 PM |
| Oil slightly overfilled on last oil change any concern? | wbradley | Issues | Warranty | Recalls / TSB | 7 | 12-22-2013 10:01 AM |
| Dealership overfilled my engine oil | mike the snake | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 50 | 12-07-2013 10:50 PM |
| Overfilled Oil | samisons | Issues | Warranty | Recalls / TSB | 10 | 12-06-2013 07:04 PM |
