Old 08-13-2012, 12:15 AM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Cylinder 4 ringland issues?
So are any of you guys who have had Sti's before worried that our new motor may suffer the dreaded ringland issues? Since this car likes to be reved. I hear horror stories about subie not honoring Warrenty and blaming the consumer for hitting red line to many times.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-13-2012, 12:22 AM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
That ringland problem is more of turbo side of Subaru. I haven't heard much on NA side... but Subaru haven't had a much high performance NA engine
Old 08-13-2012, 12:25 AM   #3
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
That was only on the 2.5 engine, and as far as I know they would replace it every time. I heard about tons of people getting new short blocks, probably just the few people who didn't get one whine the most about it
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 08-13-2012, 12:30 AM   #4
Mr. Sociable
Hombabe
Mr. Sociable's Avatar
Drives: 2014 BRZ
That, and this is a completely redesigned engine. I wouldn't worry.
Mr. Sociable is offline   Reply With Quote
Old 08-13-2012, 09:02 AM   #5
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Almost never heard about this issue on the ej207 which revved to 8k. I'm pretty sure the ringland issue was specific to the ej257 and US emissions.
industrial is offline   Reply With Quote
Old 08-13-2012, 10:17 AM   #6
Jayde
Jayde's Avatar
This. Like others have said, it's mostly cause of the turbo and emissions. I wouldn't worry.
Jayde is offline   Reply With Quote
Old 08-13-2012, 11:02 AM   #7
DarkSunrise
DarkSunrise's Avatar
Clark Tuner did a good analysis of the ej257 here. Basically he suspects a lot of the issues with detonation (and consequently cracked ringlands) on the ej257 came from it being based on the JDM 2.0L, but bored out. Basically to get it to produce 300hp on US crap gas, Subaru bored it out to 2.5L while maintaining the short stroke, causing it to be more prone to detonation than the JDM variant. Detonation is really the root cause of the cracked ringlands.
Probably more information than you wanted, but long story short, the FA20 with its square configuration (86mm x 86mm) and normally aspirated DI setup should *in theory* be less prone to detonation issues than the ej257. But only time will tell, as it's really hard to compare such different engines.
Old 08-13-2012, 11:07 AM   #8
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
You've heard wrong...
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 08-13-2012, 11:57 AM   #9
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Here's what I know about ringland failures while researching my WRX purchase:
1. They happened primarily in the '08 STIs. (The all new redesign for that year). Since then the number of reports of engines blowing in subsequent years has been reduced dramatically.
2. WRXs from the same years aren't nearly as effected.
3. Reasons for ringlands blowing are: bad tune from the factory resulting in detonation/NA emissions related, weaker cast pistons; stage 2+ abuse. Though there are generally no symptoms or signs before it does happen, making it a nasty surprise. It tends to generally happen within the first 20k.
Plus this design flaw makes the stock block just not as stout as compared to an EVO's. IF you want to sustain a lot of extra power 350-400whp+(which is a lot IMO to DD with reliably) then you'll want to buy and install stronger internals.
4. As far as warranty, I've heard of many stories of engines being covered, not being covered, covered even if modded, not covered stock...it seems like a wash. Though it'd be a safe bet to not be modded.
In the end, its not as big of a problem now as it was back in '08-'09 in the STI/WRX community, though it's still a concern in a lot of people's minds. And a lot of forums tend to suggest being careful while modding and always get a custom tune or reflash when installing things like intakes and the like.
Lastly it shouldn't have anything to do with the BRZ; like it's been stated, it's a brand new NA differently designed engine. But if you're worried about something like this happening (or any other kinds of problems), don't mod; keep receipts of your regularly scheduled maintenance and enjoy the car.
86'd is offline   Reply With Quote
Master Cylinder Brace Development - Any Interest? GrimmSpeed Brakes, Suspension, Chassis 411 05-14-2013 05:04 PM
question about cylinder walls(sleeves) carbonBLUE Engine, Exhaust, Transmission 12 04-13-2012 06:21 PM
Will we ever see a 6 cylinder engine? Bristecom Engine, Exhaust, Transmission 146 03-13-2012 07:37 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
