Old 03-22-2021, 10:13 PM   #1
series420
Drives: '13 Toyobaru BRZ
Suspension Planning, Advice requested, TY
Hello Everyone, Ive just got done completing my exhaust, and installing upgraded brakes(not brembo yet xD ), the next item on my list before FI is suspension.
Firstly Ill ask can anyone recommend a better suspension mod than
these coilovers:
https://www.ftspeed.com/part/vstd8-d...7#.YFlNZq9Kjeg
with these adjustable rear lower control arms:
https://www.ftspeed.com/part/fr-s-br...d#.YFlOIK9Kjeg
at the same ballpark cost?
Secondly Ill ask if these coilovers are worth buying or if I should wait and get something better.
Thank you all for your advice.
edit follows >
The car will be used for SCCA street prep class, and occasional runs at the 1/4. This WILL still be my daily driver, my normal commute is only 20miles per day, all on nice roads.
Aagain thank you for your advice
2013 BRZ Premium
Injen short ram intake, OFT Stage2/e85
Ftspeed UEL headers, JDL front/overpipe, HKS high power dual outlet catback
series420 is offline   Reply With Quote
Old 03-23-2021, 12:06 AM   #2
strat61caster
strat61caster's Avatar
Those lower control arms are not allowed in Street, Street Touring, or Street Prepared classes, neither is forced induction, you'll be bumped to SM or XS. Which class do you actually want to compete in since each will allow different options.
A set of Megan's or BCs are revalvable by redshift, Proparts, or Shaftworks if you decide to get serious about autox down the road for the same entry price, the teins won't scale to match competitive autox grip/spring rate/damping needs from what I can tell, but they'll be more comfortable for the daily drive. Aftermarket springs and adjustable spring perches are not allowed in Street class, but neither are lcas or bbks so that probably wasn't your plan anyway.
ineedyourdiddly
Old 03-23-2021, 11:42 AM   #3
series420
Ill have to re-research and class my car for my 'final build'
I will definitely consider the Megans.
Thank you for the info brother
2013 BRZ Premium
Planning a 2JZ GTE swap 2016 Scion FRS Advice? ZoomZoom1 Engine Swaps 36 06-20-2019 12:16 AM
tS Track Day Pads - Advice/Insight Requested J1Avs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-16-2019 03:23 PM
Advice Requested: Rebadged GT86 in the wrong location Veloist Cosmetic Modification (Interior/Exterior/Lighting) 39 07-19-2014 05:20 PM
Wheel help with 18x9.5 and 18x8.5 +35 et. Lowered, Tires. Advice requested STS-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 07-03-2014 07:59 PM
Need some Suspension advice! LazerBrZ Mid-Atlantic 6 10-09-2013 08:36 AM
