Old 03-14-2021, 11:29 AM   #1
ka-t_240
Coilover Springs
Hey Everyone - looking at changing spring rates on my RCE T2. They came with 500# springs. Been looking for some 400# springs.
The only springs I found that are 400# and available in the 6.75inch length to match the original spring length is Eibachs. But, there are only 3 in stock from what I found
I looked at Swift, and they are 7 inch length vs 6.75. Would this cause any issues?
Or is there any other brands to look at / brands to run from?
ka-t_240 is offline   Reply With Quote
Old 03-14-2021, 01:30 PM   #2
strat61caster
strat61caster's Avatar
Hyperco is good, them and eibach are my 1-2 choice.
7" should be ok, you move the spring perch down a bit to compensate and all should be fine.
ineedyourdiddly
Old 03-14-2021, 01:49 PM   #3
e1_griego
e1_griego's Avatar
Drives: Many
You're prob gonna mess with the ride height anyway, and it's a coilover, so 1/4" spring difference is sort of a 'who cares.'
I have a pair of 2.25" 400# 7" (and also a pair of 8") hypercos I can sell you.
e1_griego is offline   Reply With Quote
Old 03-14-2021, 04:23 PM   #4
ka-t_240
I am not sure if the 2.25 will work, T2 use the 60mm springs I know its a small difference but the seats and stuff may not accept them. Guessing you mean only 2 by pair?
Old 03-14-2021, 04:33 PM   #5
e1_griego
e1_griego's Avatar
Drives: Many
I have a pair of 7" 400# and a pair of 8" 400#, both 2.25".
Old 03-15-2021, 09:20 PM   #6
femaledog
Drives: 2017 BRZ Perf. Pkg.
Call RCE. They're friendly guys, I'm sure they have a good idea regarding what springs you could use.
femaledog is offline   Reply With Quote
Old 03-15-2021, 09:39 PM   #7
strat61caster
No 2.25" springs will not seat on a 60mm spring perch. If you lack the confidence to order the other poster is right, RCE will happily order a pair of springs for you.
ineedyourdiddly
On springs - add dampers or go coilover for my needs? re-animator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 03-20-2018 04:14 PM
FS: ST coilover springs (SoCal) DarkestBuddha Brakes, Suspension, Chassis 0 02-19-2014 11:44 AM
RS*R SUPER DOWN SPRINGS AND COILOVER AND MORE! ExtremeAutowerks Brakes, Suspension, Chassis 32 12-23-2013 02:39 PM
Springs/coilover recommendations? Blood Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 11-09-2013 05:49 PM
TEIN COILOVER SPRINGS jammz Brakes, Suspension, Chassis 0 04-01-2013 01:33 AM
