Old 03-12-2021, 01:40 PM   #1
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Arrow New Steering Wheel Alignment
Hi All,
I am about to install the FTSpeedFactory CR wheel. I'm pretty confident I can install it just fine, but does anyone have any tips to make sure the wheel is centered when I put the new one on? My fear is I will install the new wheel off center and it will mess-up my wheel position when tracking the car straight.
Thank you!
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 03-12-2021, 01:53 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
There are splines on the shaft and in the wheel to align it.
BigTuna is offline   Reply With Quote
Old 03-12-2021, 02:04 PM   #3
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Beauty. Thank you!
Old 03-12-2021, 02:53 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Find that section in the service manual and be super careful of the clock spring!
Link to manuals in my sig line.
Old 03-16-2021, 04:54 PM   #5
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
There should be a marking (paint marker or similar) on the existing shaft/nut showing the alignment of the current wheel to the splines. You can use this to ballpark the correct position of the new wheel. If you start with the current wheel perfectly straight, the new one should go on the same way and be easy to line up. Once you have it right, I suggest re-marking it's position in case it has to be taken off in the future.
Yes be very careful with your clockspring. The wheel will be tight on the splines even after you loosen the nut. Best practice is to loosen the nut only part way, and get the wheel loosened up on the splines first (rock it back and forth) before completely removing it. Otherwise you risk it suddenly coming loose when you pull on it and accidentally yanking off the clockspring.
wolffbite is offline   Reply With Quote
Old 03-16-2021, 09:58 PM   #6
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I’ve had the new wheel on for a few days now and it works great! I just tried to keep it centered when removing and installing. Not sure what the clock spring is? I didn’t see one and didn’t see one on 86Speed’s demo video on YouTube.
Should I be worried about the clock spring?
EDIT: Oh the airbag thing. I was very careful with that and made sure to unplug everything and re-center it when installing the new wheel.
Old 03-17-2021, 10:50 AM   #7
wolffbite
Just the tip
wolffbite's Avatar
Glad it worked!
If you had broken your clockspring, you would have been greeted by several dash lights when you first started the car.
Old 03-17-2021, 02:12 PM   #8
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Glad it worked!
God bless YouTube videos!
Old 03-17-2021, 07:50 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You have already done the deed but this is the clockspring. It is so the TCS knows the steering angle. People accidently pull this out and get it miss positioned or break it. At that point you need techstream to fix it and tell it where center is again.
https://howtune.com/articles/350-rem...baru-brz-gt-86
Old 03-17-2021, 08:44 PM   #10
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Great article, thank you. They forgot to mention the copious amounts of swearing needed on step #6!
Old 03-17-2021, 10:15 PM   #11
Ultramaroon
not playing cards
That's why you wiggle it. Wiggles and patience FTW.
Old 03-18-2021, 11:40 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't recall mine being difficult to remove.
Old 03-18-2021, 12:18 PM   #13
Ultramaroon
not playing cards
In Brahma's defense I'll say that wiggling in this context is not an innate skill. You and I have been doing it our whole lives so we don't even think about how we do it.
Retaining steering wheel controls w/ aftermarket steering wheel on +17 BRZ/86 DDavid Electronics | Audio | NAV | Infotainment 8 04-22-2021 05:37 AM
Steering wheel alignment question Keenercarguy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-22-2017 07:07 PM
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-06-2017 11:20 PM
Alignment of steering wheel changes.... DrDuquette Issues | Warranty | Recalls / TSB 7 09-14-2015 11:51 AM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
