How to stop 18x9.5 RPF1 Rubbing front fender liner at full lock
I am currently running a squared set of 18x9.5 +38 RPF1s on my BRZ. I am running KWV3 coils, around 1.5 degrees of camber, and firehawk indy 500 255/35/18 tires.
At full lock, my tires rub the fender liners, causing them to get ripped out every few thousand miles. I also have tie rod ends that allow a few extra degrees of steering angle. What are my options to stop this from happening? I would definitely consider buying two extra wheels with different offsets or widths if that would solve it. I would also consider downsizing width or height all together if thats the best option. Any and all feedback greatly welcomed. Thanks guys and gals, Blake |
Steering rack limiters.
Drives: '23 BRZ
Moar camber?
What size tires? if 255s, go to 245s which are both narrower and shorter |
AutoX-10/10ths every run
Extended studs and spacers (and lots of - camber) helped me run 295/35R17 Hoosier A7s square on 17x9.5et45 wheels.
Drives: 2016 Toyota 86
I am running 18x9.5 +36 on 245/35-18s with RCE SS-1 (KW shock so very similar to yours) and -2.7 camber up front. I don't rub on the fender liners at all. I am pretty sure you can get 255s on similar specs and not rub, too. The only thing I could think of is maybe add some more camber.
What part of your tire is rubbing? Last edited by Mike_ZN6; 03-12-2021 at 09:13 AM. |
ProCrastinationConsultant
sounds like you need duct tape deathmatch training.
#7 | |||
#8 | |
Drives: '23 BRZ
Yup, 245/35/18 fits on 8" - 9.5". Unfortunately not many 200tw "Extreme Performance" tires in that size though. If you're planning on tracking it you should go 225s on 17x8 or 245 on 17x9 IMO
https://www.tirerack.com/tires/tires...omCompare1=yes Quote:
Drives: 2018 Subaru BRZ Limited with PP
Agreed with the above that more camber sounds like your best solution with the bonus of handling improvement. If you're not tracking or doing much twisty's, then maybe a downsized tire is the better option.
| WTB: VTA Catch Can & front right fender liner | lcoopman | Want-To-Buy Requests | 0 | 05-23-2019 12:35 PM |
| Tire Rubbing Fender Liner Help | Pizzachicken | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 12-04-2018 09:59 AM |
| 17x9 +45 rubbing fender liner with coilovers | nomis | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 05-13-2016 12:41 AM |
| WTB: Raven front bumper plus front underpanel and passenger side front fender liner | THEmailman | Want-To-Buy Requests | 1 | 04-20-2014 12:05 AM |
| WTB: FRONT FENDER LINER | mr. slim | Want-To-Buy Requests | 0 | 01-06-2014 05:05 PM |
