Old 03-08-2021, 05:21 PM   #1
Enrgkid
Enrgkid's Avatar
Drives: 2013 Subaru BRZ
Clunking Coils
Hi All,
I have installed brand new Silvers Neomax S, and now when I'm driving I hear a clunk from the suspension, I cannot determine where the noise is, I have checked all the bolts. I undid the lower bolts on all four corners and then reinstalled, ensuring they were each under load when bolting it back together.
Anyone got tips on what it may be? I've read it could be top hat bolts, but I don't know what talk they need to be?
Cheers in advance.
Enrgkid is offline   Reply With Quote
Old 03-08-2021, 06:55 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Were the springs captive when you installed them?
1974 TA22 Celica
2013 86 GT
Old 03-08-2021, 06:57 PM   #3
Enrgkid
Enrgkid's Avatar
I went in and tightened them all nothing crazy but regardless still tightened them. No slack in the springs etc.
Old 03-08-2021, 07:59 PM   #4
ninjan00dles
Drives: 2015 FRS
Worn sway bar endlinks?
ninjan00dles is offline   Reply With Quote
Old 03-08-2021, 08:00 PM   #5
Enrgkid
Enrgkid's Avatar
I got new ones for the front but not the rear, might look to get new ones for the rear
Old 03-10-2021, 12:30 AM   #6
wil5bart
Drives: '16 BRZ
Check if every bolt is torqued to spec.
wil5bart is offline   Reply With Quote
Old 03-14-2021, 12:04 PM   #7
nocwage
MMTT
Drives: 2019 Subaru BRZ
When you've jacked up the car try to rock the front wheel (push the top outside in and pull the bottom outside out and then the opposite) if you were in front of the car you'd be trying to make the wheel go / | \ (so not rotation you'd have for turning the wheel, it's trying to make the top and bottom of the wheel move in and out).
If it moves a lot (we're talking centimeters, usually you could like slide the wheel in with a loud clunk and it would stay until you pulled it back) you probably didn't tighten the large bolts at the knuckle enough (they should not move and need to be very tight with a high lb-ft).
If it just moves a little check to make sure the lower collar that tightens to where the shockbody enters the lower mount is fully tight. I had an issue with that lower mount getting loose on my FA500 and then I got a clunk when turning, they recommend using a flathead screw driver and a hammer to force the collar to rotate, the tools people think are for tightening are meant just to adjust the height, they will not tighten it enough to hold.
nocwage is offline   Reply With Quote
Old 03-17-2021, 08:04 PM   #8
strat61caster
strat61caster's Avatar
Top nuts also come loose along with swaybar end links causing a 'clunk', zap those with an impact driver.
My left rear started clunking a few days ago after hitting a pot hole.
ineedyourdiddly
Clunking noise help MotoX16 Issues | Warranty | Recalls / TSB 41 03-02-2022 08:17 AM
Clunking from rear end dustmann Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-04-2020 07:02 PM
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Suspension clunking (i think) BRZ'13 Issues | Warranty | Recalls / TSB 15 09-21-2016 11:53 AM
Transmission Clunking (A/T) Mr. J Issues | Warranty | Recalls / TSB 6 01-01-2013 07:11 PM
