Old 02-28-2021, 05:42 PM   #1
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
EcuTek and Torque Pro monitoring oil temp
Hi everyone, I've got a question regarding the Torque Pro compatibility with the EcuTek. I've got a stock 2020 86 Base model and say I buy a Bluetooth OBDII adapter and get a Torque Pro app to monitor oil and coolant temps, will it work after a have an EcuTek tune or I'll have to buy their proprietary adapter and use their app?
Arthur-A is offline   Reply With Quote
Old 03-01-2021, 11:38 AM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Pretty sure a tune should have no affect on capability of getting readings from the ECU through something like Torque Pro. You can use either after a tune. Though I must say, I like EcuTek's interface and it is adjustable, much like in Torque Pro. I would like to think the EcuTek adapter is a good one and provides accurate and quick readings as well vs most OBDII adapters out there aside from the more expensive ones possibly.
Dzmitry is offline   Reply With Quote
Old 03-01-2021, 04:51 PM   #3
Arthur-A
Arthur-A's Avatar
Good to know, thanks! I'm planning to get a tune later down the road, but I'd like to see what my oil temp is right now.
Old 03-02-2021, 07:19 AM   #4
Dzmitry
Dzmitry's Avatar
In a 2017+, you can read your oil temp and coolant temp from the gauge on the screen.
Old 03-02-2021, 12:50 PM   #5
Arthur-A
Arthur-A's Avatar
I have a Base model, it has only basic display.
Old 03-02-2021, 12:56 PM   #6
Dzmitry
Dzmitry's Avatar
Ah yes, sorry I got mixed up with the BRZ, which did not hold the base model in 2020.
Old 03-02-2021, 01:09 PM   #7
Arthur-A
Arthur-A's Avatar
Yeah, I was a bit surprised that it didn't have that fancy cluster with the display, but as long as there's a way to get those readings, it's not a big deal.
Old 03-02-2021, 10:09 PM   #8
kev0
Drives: '14
For those who don't know:
If you have a jailbroken iPhone, you can use the tweak 'CarBridge' to display your EcuTek gauges (assuming you have the Bluetooth adapter) onto your headunit.
kev0 is offline   Reply With Quote
Old 03-02-2021, 11:32 PM   #9
ls1ac
ls1ac's Avatar
Just for FYI, usually you can not use two OBD2 devices at the same time . There are a few that will work together at the same time but one must be a monitor only. I have tried several using a "Y" cable. Where CAN buss is designed to work with many.
Old 03-03-2021, 05:49 AM   #10
Deisou
Drives: 2013 Subaru BRZ
So will the Y cable work if I wanted to run RaceChrono to log out things like RPM whilst also running a OBD2 gauge? Both read only.
Any hit to the data throughput especially for RPM logging?
Sent from my SM-G965F using Tapatalk
Deisou is offline   Reply With Quote
Old 03-03-2021, 07:45 PM   #11
ls1ac
ls1ac's Avatar
I do not know about those two. As i said the only way is to try. Some you may think are read only are poling for information.
Torque App not reading Oil temp properly dazbrz Engine, Exhaust, Transmission 8 01-15-2021 07:03 AM
How is Torque Measured? (EcuTek) Dzmitry Software Tuning 1 01-15-2020 09:36 AM
Worlds Highest Power and Torque FR-S Tuned on EcuTek EcuTek Forced Induction 64 09-03-2015 12:19 AM
Torque app with oil temp aaronsadventures Electronics | Audio | NAV | Infotainment 0 09-08-2014 09:14 AM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
