Old 01-15-2020, 09:17 AM   #1
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
How is Torque Measured? (EcuTek)
I was just thinking... when using EcuTek, I can get a parameter for "Torque Actual (Nm)." This popped a couple questions in my head. How accurate is this measurement, or better yet, how is this parameter determined/calculated? Based on my readings after a tune, I peaked out at nearly 179 ft-lbs of torque after I converted it from Nm. This leads me to believe it probably isn't all that accurate as I doubt I'm pushing 179 ft-lbs after a basic tune with no mods. I do notice that it follows the torque curve quite accurately based on the RPM in general. So I was just curious if anyone knew how this parameter is calculated while driving?
Dzmitry is offline   Reply With Quote
Old 01-15-2020, 09:36 AM   #2
tomm.brz
Drives: brz 2017 hksv2
it is not measured, it is a fictitious value used to handle the throttle valve
if you modify the tune, you could even make it showing 900 Nm
don t look at it.
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
DarkPira7e (01-15-2020), Dzmitry (01-15-2020), JohnJuan (01-15-2020)
Worlds Highest Power and Torque FR-S Tuned on EcuTek EcuTek Forced Induction 64 09-03-2015 12:19 AM
anyone measured how loud in decibels the invidia N1 is sci3 Engine, Exhaust, Transmission 6 06-21-2015 12:08 PM
Performance exhaust measured noise levels? stonenewt Engine, Exhaust, Transmission 4 09-30-2014 05:02 PM
Measured: Aero Lift, Roll Stiffness & Distribution, Steering Effort, and more DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 32 07-03-2014 07:25 PM
Dealership to Dyno: Our FR-S gets measured Arsenal Autosport Engine, Exhaust, Transmission 21 05-30-2012 06:55 PM
