Old 02-22-2021, 07:26 PM   #1
Rookie_34
Drives: 2014 frs
OLM headlight help!
Hey guys, I got a new set of OLM headlight from ftspeed. I don’t know if this is a newer kit/wires. I’m pretty sure I hooked it up correctly but the boomerang doesn’t come on during drives. It only comes on if I turn the headlights on. I watched plenty of YouTube videos. Does anyone have a newer OLM kit? And does your boomerang come on drive? Any help please
Rookie_34 is offline   Reply With Quote
Old 02-22-2021, 08:44 PM   #2
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Hope this helps you out!
scion fr-s is offline   Reply With Quote
Old 02-22-2021, 08:50 PM   #3
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
What car is this going on?
Drifter X is offline   Reply With Quote
Old 02-22-2021, 10:44 PM   #4
Rookie_34
Drives: 2014 frs
Nope, I watched him already. I’m sure everything is plugged up correctly, I just need someone to confirm that the boomerang only comes on when the headlights are turned on.
Old 02-22-2021, 10:47 PM   #5
Rookie_34
Drives: 2014 frs
It’s a FRS. So I did splice the turn signal and connect the 3 wires. Everything works, I just don’t believe that the boomerang only comes on when the light is turned on. Like when I had my stocks, with e brake down, the DRLS are on. I just don’t believe it.
Old 02-22-2021, 11:04 PM   #6
Drifter X
Drifter X's Avatar
Are you using the adapter harness that comes with in the box?
Old 02-22-2021, 11:12 PM   #7
Rookie_34
Drives: 2014 frs
Yes I am. The more I research, I’m starting to think this is how it’s supposed to be. I read some brz owners actually had to hardwire the DRL/boomerang into the accessory wire, which I will have to locate if I wanted it on. I hate to believe it but all of the YT videos I’ve watch. You can tell they have their lights turned on first click cuz the tail light is red.
Old 02-22-2021, 11:56 PM   #8
Drifter X
Drifter X's Avatar
Yeah you will need to tap the boomerangs to a accessory 12v source. Even on my 2019 86, the harness it comes with is pretapped to the 12v for the headlight adjuster motor.
Old 02-23-2021, 12:25 PM   #9
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
This is because boomerangs are not DRLs. Even on stock BRZs they are like this (without an aftermarket module).
sharpsicle is offline   Reply With Quote
First only left headlight works, then only right headlight russsak Cosmetic Modification (Interior/Exterior/Lighting) 2 09-23-2020 03:05 PM
BRZ headlight shroud inside FRS headlight? S84kam Cosmetic Modification (Interior/Exterior/Lighting) 9 04-02-2016 12:24 AM
WTB Headlight balla_08 Exterior Parts (Aero, Lighting, Etc.) 0 12-16-2013 10:17 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
Where can i get this headlight? remorse87 Cosmetic Modification (Interior/Exterior/Lighting) 16 10-25-2012 06:01 AM
