Old 02-17-2021, 01:19 AM   #1
lrae21
Drives: 2012 Toyota 86 GTS
Exhaust issues
Hello,
I have a 2012 Toyota 86 with an Invidia N1 and Tomei uel headers. Recently I blew the cat and took it to an exhaust repair shop that fitted a universal high-flow cat to replace it. The exhaust note has dramatically changed and become much quieter, as well as driving a bit sluggish. Anyone have similar experience or know of any potential solutions? Cheers.
lrae21 is offline   Reply With Quote
Old 02-17-2021, 02:27 AM   #2
suppjc
Drives: 2015 Scion FR-S Firestorm
Not sure about the drivability (likely due to the change of exhaust gas flow, just a guess), but I've heard the size of a cat (or a different cat) can change how the exhaust sounds. Hope you won't have an issue.
suppjc is offline   Reply With Quote
Old 02-17-2021, 02:30 AM   #3
Purist
Purist's Avatar
Drives: Subaru BRZ
Hey mate. Do you mean 'blew' your cat as in the actual guts blew out? If so then your exhaust became more free flowing and would have been a free performance upgrade.
Your new cat is restricting flow compared to the old one that was probably disintegrated.
Get the exhaust shop to delete it (replace it with a straight through pipe) to get your sound and performance back.
I run UELs and a Q300 and no cats.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 02-17-2021, 02:33 PM   #4
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
How do you blow a cat? (srs)
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 02-17-2021, 02:35 PM   #5
MJones_RB
MJones_RB's Avatar
MJones_RB is offline   Reply With Quote
The Following 2 Users Say Thank You to MJones_RB For This Useful Post:
finch1750 (02-17-2021), Tcoat (02-17-2021)
Old 02-17-2021, 02:43 PM   #6
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Originally Posted by MJones_RB View Post
Knew this was coming...meow
Old 02-17-2021, 02:45 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Usually from heat. Kinda weird he blew a front pipe cat. Usually FI guys have to worry about it or people running pop tunes.
BrahmaBull1990 (02-17-2021)
Old 02-17-2021, 02:46 PM   #8
BrahmaBull1990 (02-17-2021), finch1750 (02-17-2021), MJones_RB (02-18-2021), NoHaveMSG (02-18-2021)
Old 02-17-2021, 02:47 PM   #9
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Okay, thank you. This is my 10th post, maybe I can "thanks" now
Old 02-17-2021, 03:13 PM   #10
A bad tune can burn one out in short order. Used to be a fairly common issue back in the early 90s when people were still learning how to tune ECUs. Too rich will flow more fuel into the cat than it can handle and POOF there it goes.
Old 02-17-2021, 04:15 PM   #11
Purist
Purist's Avatar
Drives: Subaru BRZ
So would runing rich actualy physically disintegrate the substrate, or just stop it catalysing?
Im guessing one of those stupid pop tunes would physically damage it.
Less More
Old 02-17-2021, 07:11 PM   #12
finch1750
finch1750's Avatar
Right, at the basis I understood it as misfires or running rich creates more heat and damages them. Or does the fuel itself cause issues with something like combustion in the cat since it holds so much heat itself
Old 02-17-2021, 07:47 PM   #13
Both. I the case of the "pops" they of course are putting rapid pressure on the cats which are just simply not designed for such abuse.
catalytic converter, exhuast
Understeer Issues - Toe Alignment Issues? NutGud Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-29-2021 08:45 PM
VVT Issues bobmcboberston Issues | Warranty | Recalls / TSB 2 06-28-2019 07:17 AM
Exhaust Issues bozack Engine, Exhaust, Transmission 23 04-16-2015 01:21 AM
Oft e85 issues sosick Software Tuning 14 05-22-2014 05:40 PM
Any issues with this setup? Headers/Exhaust Jepaton33 Engine, Exhaust, Transmission 3 04-09-2014 09:33 AM
