Old 02-14-2021, 11:58 AM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
Should the car be on or running when I hook up the obd2 scanner?
Did a search and I can’t find the answer. Any help greatly appreciated.
Jstyle is offline   Reply With Quote
Old 02-14-2021, 12:21 PM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
I use either an Autel 319 or 519 OBD scanner. Both manuals say:
"CAUTION: Don’t connect or disconnect any test equipment with ignition on or engine running."
LimitedSlip is offline   Reply With Quote
Old 02-14-2021, 12:47 PM   #3
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
+1^^^
gen3v8 is offline   Reply With Quote
Old 02-14-2021, 02:41 PM   #4
ls1ac
ls1ac's Avatar
After you hook it up put the car in ON but not running to read codes.
Old 02-14-2021, 06:38 PM   #5
Jstyle
Jstyle's Avatar
Drives: 2020 86
So my thought is, after I disco’d the battery to reset EVERYTHING yesterday, I’ll take it out for a spin tomorrow get it up to operating temps. Then I’ll turn the car off, connect the scanner, then put it in Run with out actually cranking it. That sound right?
Old 02-14-2021, 06:52 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
if you disconnect the battery to reset everything, it resets all the system monitors as well. if you're attempting to chase a service engine light, some situations, that would clear the light.
don't disconnect the battery.
OBD2 scanner for monitoring oil pressure? chipmunk Engine, Exhaust, Transmission 7 10-06-2020 07:55 AM
Bluetooth OBD2 Scanner Question FR-S2GT86 Software Tuning 5 04-15-2020 02:50 PM
3D Model Scanner Bach415 Northern California 0 12-19-2017 03:38 AM
ACTRON OBDII scanner BRZ-y Electronics | Audio | NAV | Infotainment 2 01-28-2016 05:37 PM
New 3D laser scanner and printer what to make? SpeedR Scion FR-S / Toyota 86 GT86 General Forum 69 06-11-2013 08:14 AM
