Old 10-03-2020, 10:12 PM   #1
chipmunk
Drives: _
OBD2 scanner for monitoring oil pressure?
Does our OBD2 port give out any info on oil pressure? I wanna see if there's a quick and easy way of monitoring oil pressure using a Bluetooth OBD2 device.
I have a cheap OBD2 scanner on Amazon. It has most info, except oil pressure. Attaching a screenshot. I wonder if there are other devices that can read pressure??Name:  Screenshot_20201003-211111.jpg
Sent from a potato
chipmunk is offline   Reply With Quote
Old 10-03-2020, 10:19 PM   #2
Gloonge
Drives: 2013 frs raven
I have a cheap OBD2 scanner on Amazon. It has most info, except oil pressure. Attaching a screenshot. I wonder if there are other devices that can read pressure??Attachment 193408
Sent from a potato
The oil sensor on these Motors is just a switch. No pressure reading available without an aftermarket sensor.
Gloonge is offline   Reply With Quote
Old 10-05-2020, 11:09 AM   #3
chipmunk
Drives: _
So..... the only way to measure oil pressure is to install an aftermarket gauge into the front cover?
Old 10-05-2020, 02:36 PM   #4
Gloonge
Correct, you can remove the factory pressure gauge and use that port, or you can install a sandwich plate on the filter.
Old 10-05-2020, 04:03 PM   #5
fminicooper
Drives: FRS Hot Lava
There's an oil galley plug, under and to the left of the air condition pump. I uded for my oil pressure gauge.
fminicooper is offline   Reply With Quote
Old 10-05-2020, 04:45 PM   #6
chipmunk
Drives: _
Yea, so.... the service manual specs are written for the current sensor location. So if I were to install a gauge for monitoring, it's best to use that location to compare against OEM specs
Sent from a potato
Old 10-06-2020, 08:52 AM   #7
Gloonge
Sent from a potato
I made the same assumption. I figured the easier oil gally plug would be inaccurate. The adapter under the oil filter would render the same results as the factory spot though.
When you Un hook the original single wire plug you can just leave it Un hooked, it does not throw any lights.
Old 10-06-2020, 08:55 AM   #8
chipmunk
Drives: _
To clarify, is the OEM sensor location 1/4" or 1/8"?
Maybe I can find a T at local hardware store...
Sent from a potato
Bluetooth OBD2 Scanner Question FR-S2GT86 Software Tuning 5 04-15-2020 03:50 PM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 01:54 PM
Tyre Pressure Monitoring Systems Fish Eagle AFRICA 3 07-14-2013 05:52 PM
New Tire Pressure Monitoring Sensors? Kochinopride Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-14-2013 09:51 PM
WTB: Tire Pressure Monitoring Sensors (TPMS) RYU Wheels and Tires 6 09-18-2012 01:52 PM
