Old 02-14-2021, 12:07 AM   #1
dazhbucked
Drives: Subaru BRZ 2014
What should I do if car has been unused for more than 5 months
Hey everyone I wanted to ask y’all for your tips. My car has been unused for more that 5 months, it has been covered with a high quality car covered and with the battery unplug, but standing still on dirt. If you guys can help me, what are things I should look for before using my car again?, what are the prone things to messed up or what should I do?.
I also heard that you can prime the oil and fuel pump by pressing the clutch and gas pedal and turning the vehicle, but how exactly does this work?, and what should I left off first?
dazhbucked is offline   Reply With Quote
Old 02-14-2021, 12:17 AM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
pull the fuel pump fuse or relay out crank the car until the oil oil light goes out. put it back in turn on reds but dont start. turn off and then normal start. Check fluids etc first of course
The Following User Says Thank You to gen3v8 For This Useful Post:
Ultramaroon (02-14-2021)
Old 02-14-2021, 12:19 AM   #3
azeo
Drives: 2014 FRS Ultramarine
Pretty sure you can cut fuel simply by staying at full throttle while cranking can't you? Same idea though, crack the engine with no fuel to get oil circulating before trying to start it.
Sent from my ONEPLUS A5010 using Tapatalk
azeo is offline   Reply With Quote
Old 02-14-2021, 01:01 AM   #4
^^ this ^^ Can read about it in the owner's manual. I think it's called the flood-clearing mode.
Except the evil side of this technique is that while stepping on the clutch, any existing lubrication is being squeezed out of the thrust bearings. Out of principle, I've been bypassing those stupid clutch safety interlocks ever since they first appeared. Can only do that with a key start.
Just fire it up. It'll be fine.
humfrz (02-14-2021), The Red One (02-15-2021)
Old 02-14-2021, 01:11 AM   #5
dazhbucked
^^ this ^^
Thanks!, I’m just going to start it up since my car is keyless, I hope everything goes fine
Old 02-14-2021, 04:07 AM   #6
Yep, check the oil level, air up the tires, charge up the battery - then fire that motha up -
soundman98 (02-14-2021), The Red One (02-15-2021)
Old 02-14-2021, 06:44 AM   #7
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Air in the tires definitely helps with a fire up
But the OP does say car not just engine....So...
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
humfrz (02-14-2021), Ultramaroon (02-14-2021)
Old 02-14-2021, 06:11 PM   #8
I see that you read his post with more clarity this morning.
I WAS going to you last night for your lack of reading comprehension, but I'll cut you a brain fart on that one.
gen3v8 (02-15-2021)
Old 02-14-2021, 09:26 PM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I would start it and drive It like I stole it. It is a fucking twin.
Mr.ac (03-29-2021), soundman98 (02-15-2021)
Old 03-02-2021, 10:54 PM   #10
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I've let mine sit for two weeks while on vacation a few times before. 14 FRS for reference. On one trip, it was a bit rattly for about 1-2 seconds before the oil pressure kicked in. Don't wick the throttle and send your bearing loads skyrocketing.
I've had it do on it my other boxer subarus over the years as well for reference. Never more than just the usual bit of tiny shiny bits in the oil as usual. Actually, on my FRS, cleanest oil changes I've ever seen in regards to the shiny bits.
jeepmor is offline   Reply With Quote
Old 03-03-2021, 01:39 PM   #11
These and all other cars can sit for weeks and months before they are even owned. They do not go through any special start up procedures when they do get started.
It is one startup and even at it's possible worst it took .00001 minutes off the life expectancy of the car.
soundman98 (03-03-2021)
Old 03-03-2021, 07:45 PM   #12
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Flush the squirrels out of the CAI and you should be good to go.
The Following 2 Users Say Thank You to bcj For This Useful Post:
Overdrive (05-29-2021), soundman98 (03-03-2021)
Old 03-03-2021, 09:04 PM   #13
ls1ac
ls1ac's Avatar
Mine sits seven months over the winter every year. Check battery tires fluids and start. So far no problems i know of. Bought it new in 2013.
EDIT I do use a good quality battery maintainer.
EDIT2 I add Stable and fill the gas tank.
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
soundman98 (03-03-2021), The Red One (03-04-2021)
Old 03-03-2021, 11:12 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
my favorite thread was the one that people new to storing their car started randomly speculating that any amount of gas sitting in the tank over 1 week would go so bad that it would need to be pumped out and the entire system flushed...
The Following 5 Users Say Thank You to soundman98 For This Useful Post:
ddevl_86 (03-06-2021), Dzmitry (03-04-2021), NoHaveMSG (03-04-2021), Tcoat (03-04-2021), The Red One (03-04-2021)
What do you guy's do with the unused oil? lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 02-14-2016 05:36 PM
FS: NEW UNUSED Bridgestone Potenza RE-11s set of 4. BRZZZZZZZZZZ Canada Classifieds 3 05-14-2014 09:47 AM
For Sale: SPC LCA ***NEW*** unused dkx64 Southern California 0 03-21-2014 01:05 PM
SOLD - 3 BAR Map sensor NEW, unused Amadeus Engine, Exhaust, Bolt-Ons 2 08-19-2013 01:25 PM
Storing an unused car? #87 Off-Topic Lounge [WARNING: NO POLITICS] 10 02-21-2012 11:51 PM
