Old 02-12-2021, 08:29 AM   #1
Sniepster
Drives: 2013 Toyota 86
Transmission whine
So i've had my car for about 4 months now and it hasn't had any problems.
However the car has always had this whine that seems to come from the transmission when it's under load. It literally sounds like i have straight-cut gears, which makes it sometimes fun but at highway speeds kind of annoying.
Is this sound normal? Are our trannies supposed to whine?
Sniepster is offline   Reply With Quote
Old 02-12-2021, 09:38 AM   #2
Change the TOB and see if the noise changes. These trannys do make noise though. All trannys do but you usually can't hear it through the sound proofing. These have very little covings to muffle the sound so you hear a bit more.
Old 02-12-2021, 11:35 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Is the car stock? Have you checked it for mods?
Old 02-12-2021, 12:16 PM   #4
Sniepster
Car is completely stock except for lowering springs. It has also had a transmission oil change at the dealer 10k miles ago so that can be ruled out.
Old 02-13-2021, 08:06 AM   #5
ermax
ermax's Avatar
These tranny whine a lot. It’s normal.
The Following User Says Thank You to ermax For This Useful Post:
tomm.brz (02-15-2021)
Old 02-13-2021, 10:52 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, imho they don't whine that much, if with stock bushings. It's when one starts changing out different bushings for gearbox/transmission/rear subframe & diff to less compliant ones for whatever other NVH unrelated reasons..
Old 02-13-2021, 10:25 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'll tell my story again.
Back when I had about 12 Kmi on my original pristine transmission, I did a dumb show-off move when a buddy egged me on. It induced some nasty wheel hop and even though I unloaded it as quickly as possible, the damage was done. I heard a teeny whine. In the desire to preserve my original, I immediately swapped in a used transmission. Fuck me! It was a loud whiny bitch right off the bat. Way worse than my first but I just shrugged it off and kept driving for science. I'm now at 60 Kmi and the whine hasn't changed one bit. No worse at all.
I guess what I'm saying is, IMO, they're only super quiet when they're perfect. A little whine is no biggie. Does it bug me? Yeah, but I'm lazy too.
BrahmaBull1990 (02-27-2021)
Old 02-14-2021, 04:02 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Funny, but some of noises might come not from gearbox itself. For example - some rattle noises may come from loose cap on stock shifter gear knob. And with some less compliant tranny/gearbox/diff bushings one of extra noise source is clutch, that adds it's "voice". Though it usually then comes in chorus with gear whine of gearbox-es first gears.
Old 02-15-2021, 02:32 AM   #9
Decep
Drives: 2013 FR-S Series 10
Mine is quiet under load, but cruising in 6th at 75 mph theres a bit of whine to it. It was annoying at first but you get used to it.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 02-17-2021, 03:02 PM   #10
Ultramaroon
not playing cards
That's the stock diff. There's a resonance right at that speed. Here's the definitive test. Fifth gear is a straight shot through the transmission. It's not doing anything. If there's any whine that does not go away in fifth, it's not the transmission.
jcw99 (02-18-2021)
Old 02-18-2021, 08:06 PM   #11
SydBRZ
SydBRZ's Avatar
Drives: MY14 BRZ, MY06 WRX
Whine in the transmission... have you tried drinking it?
Might go well with a burger.
(Now that you've had helpful replies, couldn't resist, sorry )
SydBRZ is offline   Reply With Quote
The Following User Says Thank You to SydBRZ For This Useful Post:
soundman98 (02-19-2021)
Old 02-21-2021, 01:00 AM   #12
jflogerzi
jflogerzi's Avatar
This 100%. When I did the white line + Perrin transmission mount combo it completely changed the in cabin noise under highway driving and under hard acceleration. Almost wish I left it alone
2013 Series 10 FRS #553
Old 02-21-2021, 01:26 AM   #13
Decep
Thats from the whiteline insert, i have the perrin rear mount and it adds zero nvh. Pretty nifty little part. I tried the whiteline insert and didn't care for it either
RCE SS-1 Coilovers
Corsa Catback
Old 02-21-2021, 01:27 AM   #14
jflogerzi
jflogerzi's Avatar
Next time I have some work done at the shop I will have it removed.
Engine/transmission high pitch whine DandoX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 07-18-2018 02:46 PM
Strange whine after installing transmission/other upgrades takethecake Engine, Exhaust, Transmission 3 07-23-2017 08:08 PM
Trans whine? MisterSheep Issues | Warranty | Recalls / TSB 50 02-12-2016 10:37 AM
2013 FR-S A/T whine.... Tromatic Engine, Exhaust, Transmission 6 01-20-2014 12:57 PM
AT trans whine? Anyone else? Hardrock4445 Engine, Exhaust, Transmission 1 05-30-2013 06:46 PM
