Old 07-23-2017, 03:41 PM   #1
takethecake
Strange whine after installing transmission/other upgrades
Hey guys, got a question for you. I just finished doing a little work on my 2013 BRZ - mainly installing the Perrin shifter bushing, Whiteline gearbox positive shift kit, and MTEC shifter springs. I had to drop the front pipe to do the mods, and before putting it back on, I replaced one of the stock exhaust gaskets (FP-to-catback) with a new grimmspeed multi-layered gasket since the original had basically disintegrated into nothing. While I had the car on stands, I also checked my brake pads and replaced my brake fluid (including replacing both front bleeder valves since I mangled them trying to get them off...).
The first thing I noticed when I took it for a test drive was a whining noise that I don't remember being there before; I also thought the exhaust note sounded a bit different than I remember. I'm guessing I had a small leak due to the tattered original gasket. I'm running a JDL UEL catted header, JDL overpipe/"ultra quiet" catted frontpipe, and a perrin 3" resonated catback. My other two stock gaskets (header-to-OP, OP-to-FP) were destroyed in a similar fashion - I guess those gaskets aren't able to handle the increased emissions from higher flowing cats?
Anyhoo, I don't think there's anything wrong, but just thought I'd ask you guys to listen and see if anyone has any ideas of what changed. It's easier to hear near the end of the video as the speed increases - kind of sounds like a faint supercharger whine almost (I do not have any FI installed lol).
Thanks!
takethecake is offline   Reply With Quote
Old 07-23-2017, 03:44 PM   #2
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I hear nothing wrong, but note that the parts you replaced were designed to decrease nvh, while the parts you installed ignore it completely, so it is not surprising to hear some little extra noise you never heard before. As long as the parts are installed right there is nothing wrong that I can hear.
Old 07-23-2017, 08:37 PM   #3
RJasonKlein
RJasonKlein's Avatar
It's normal - mine does the same thing with identical parts installed.
RJasonKlein is offline   Reply With Quote
Old 07-23-2017, 09:08 PM   #4
takethecake
That's a good point - I hadn't really thought about that. I was definitely more curious than concerned; thanks for the replies guys!
SSP A960E Transmission Upgrades sspkris Engine, Exhaust, Transmission 123 06-10-2022 12:40 PM
Help wanted: Soundproofing and installing small upgrades (Lynnwood, WA) chezzy79 Northwest 19 03-10-2016 07:29 PM
First upgrades to the transmission rns294 Engine, Exhaust, Transmission 5 12-23-2015 04:45 PM
Need Transmission Upgrades for Turbo? Admired Forced Induction 26 11-10-2013 03:48 PM
Transmission moving after upgrades? Sniper2606 Engine, Exhaust, Transmission 2 07-10-2013 02:54 AM
