Old 02-11-2021, 08:38 PM   #1
Saskatuon
Drives: 2017 Brz
Unhappy Alignment check
Help, i recently installed LCAs and rear toe arms, i then got an alignment at a custom shop (before measurements) then took it to firestone and got it aligned (actual measurements). The problem i am having is while turning left or right on a curve the car starts to lose traction and the traction control light flashes.
was not doing this before the install and alignment. would this be something with the parts i put on or the alignment. i have taken the car on these roads many times and never lost traction at higher speeds than i am now. The car is on bc racing coilovers which ive been running for about 4 years. any help is greatly appreciated!
Saskatuon is offline   Reply With Quote
Old 02-11-2021, 09:04 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
For what it's worth I typically run about one degree of camber more in the front than the rear. I suspect your car is under steering badly.
Old 02-11-2021, 09:12 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
"Actuals" are current, right?
If measurements are accurate, your rear toe-in was WAY off before, 1.3 degrees total is insane!
Nothing I'm seeing in your current alignment looks off, but you might see if you can check at another shop to confirm.
Did you get LCAs to reduce rear camber? Looks like they evened rear camber out left/right but toward the higher end a bit. Not that I think 3 degrees should give you any problems, but for street car you might want more like -1.5 to -2 degrees.
Old 02-11-2021, 09:22 PM   #4
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
If you took it to a custom shop and got an alignment why did you get another at Firestone. Unless you mean you got it measured at a custom shop first.
Seems like they only adjusted some toe as its all over the place. What specs did you ask them for? It`s not even in their specs. Higher quality picture helps
gen3v8 is offline   Reply With Quote
Old 02-11-2021, 10:11 PM   #5
Saskatuon
Drives: 2017 Brz
i took it to a custom shop after the install planning for it to be my only alignment but it felt horrible after so i wanted a second opinion. turns out it was the toe being far off.
Old 02-11-2021, 10:13 PM   #6
Saskatuon
Drives: 2017 Brz
my plan was to reduce camber i bought the lcas 3 years ago and just decided to put them on since i had them tbh
the before was from the custom shops first alignment sadly they didnt have any info on the before, they didnt even give me a alignment sheet after. was a bad shop i regret it but i guess you live and you learn.
Old 02-11-2021, 10:15 PM   #7
Saskatuon
Drives: 2017 Brz
i went for a drive without tc on, dont know if it was smart or not, but the car drove basically perfect didnt feel anything weird, thinking the sensor got messed up during install maybe? all i can really think of at this point.
Old 02-12-2021, 02:42 AM   #8
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
The wheel alignment is not good the car would not be balanced. It needs to be set up within its adjustment parameters properly front to rear. Apart from a problem. Like i asked
you what specs did you ask for
Old 02-12-2021, 07:35 AM   #9
Grady
Grady's Avatar
Ok some simple questions, Tires worn evenly? Tire pressures even?
Your camber is not matched well in the front, to much camber in the back(my opinion)
alignment, coil overs, grip, help me, suspension
Can someone please check my alignment specs? boring86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-28-2019 09:50 AM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Need Serious Alignment Check, Suspension Damage? Staf00 Southern California 6 05-29-2014 11:49 PM
Alignment Sanity Check FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-16-2013 07:18 AM
