Old 02-08-2021, 09:55 PM   #1
Deemsim
Drives: 2013 Gt86
Bonnet alignment
Hi,
My 86 has an uneven bonnet gap, (larger gap on the drivers side compared to the passenger side).
I was just wondering if there's a correct way to shift the bonnet left/right? i've never touched the bonnet before so i dont want to do anything that'll make it worse.
I'm aware that people recommend to unbolt the top fender mounts and move it inwards/ outwards to get the right fitment. However i'm reluctant to do this as the drivers side wheel is already poking out more than the passenger side.
I'm hoping to move shift the bonnet closer towards the drivers side and then adjust the fender on the passenger side to make the gap even.
Hope this makes and any help on how to do this would be great.
Deemsim is offline   Reply With Quote
Old 02-09-2021, 06:13 PM   #2
Grady
Grady's Avatar
Yes loosen the bonnet bolts and shift the hood. Also a big rubber mallet can correct gaps.
Old 02-10-2021, 03:23 AM   #3
Deemsim
Drives: 2013 Gt86
Thanks, im just anxious that if i loosen the bolts it will move in towards the cowl, how can i ensure that this wont happen?
Old 02-10-2021, 07:47 AM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Pretty good info about adjusting the hood (bonnet) here: https://www.ft86club.com/forums/showthread.php?t=127357
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
Deemsim (02-11-2021)
Old 03-24-2021, 10:29 PM   #5
nemu-iii
Had this issue previously, surprisingly the fix is to adjust the top 3 bolts of the side fender that you want to align the hood to the side that is affected. Hope it helps
nemu-iii is offline   Reply With Quote
Old 03-25-2021, 01:40 AM   #6
86TOYO2k17
Drives: 2017 toyota 86
You have 4 bolts 2 on each hinge that can be loosened push the hood over to the direction needed to lessen gap tighten bolts, check gapping rinse and repeat. You can also do the same if the front is off by looseneing and shifting over the latch. It is all actually really pretty easy. I had a seibon carbon fiber hood that had a large gap on driver side at top side of hood but almost no gap driver side bottom side. Basically it was angled. By adjusting those 3 points I mentioned i got it 100% perfect fitment everywhere.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
M0nk3y (03-26-2021)
FS: VARIS cooling bonnet hood 2 Chris6052 Canada Classifieds 10 08-18-2017 07:59 PM
South Africans - any of you know what bonnet this is? nzer AFRICA 8 06-20-2014 08:11 AM
Hood/Bonnet Lifting At Speed Kefuddle Issues | Warranty | Recalls / TSB 14 06-14-2013 05:44 AM
Ceramic coating and under the bonnet tempatures. Adeets Engine, Exhaust, Transmission 8 04-06-2013 09:12 AM
Syms - Bonnet Damper Beyer Subaru Cosmetic Modification (Interior/Exterior/Lighting) 6 02-25-2013 03:41 PM
