Old 05-02-2018, 04:53 PM   #1
Chumblebee
yabai
Chumblebee's Avatar
Hood Gap Fix
Ever since I went boost my hood has not been lined up with my fender and sticks up too much. It creates a big gap and looks awful but I have no clue what it could be. I haven't touched the hood or how it aligns. Thanks.
If I push down on the hood then it seems to align good but as soon as I let up it goes back to how it was.
Chumblebee is offline   Reply With Quote
Old 05-02-2018, 04:58 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My guess is something is slightly in the way. Do you still have the hood pad? Is it dented?
I LIKE TIRES!
Old 05-02-2018, 05:47 PM   #3
redhalo
Drives: MY20 Hakone Toyota 86
Adjust the rubber stopper thing under the hood. It turns like a screw and raises or lowers either side front corner.
redhalo is offline   Reply With Quote
Old 05-02-2018, 08:07 PM   #4
Chumblebee
yabai
Chumblebee's Avatar
I had already adjusted the rubber pads all the way down prior to the pics. I will double check though.
Yes, I still have the pad but its not dented, the only thing that could be touching it is the bigger AC line that runs to the condenser but even after tucking it under something, the hood stays the same.
Old 05-03-2018, 04:36 PM   #5
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Does the hood latch fully, and if so does it latch with ease? If it does, the latching mechanism may be too high and isn't holding it down enough.
sharpsicle is offline   Reply With Quote
Old 05-03-2018, 08:14 PM   #6
Sharp got it. Loosen the bolts and move the latch down a hair. I had to do that with mine.
Old 05-21-2018, 01:54 PM   #7
DeaconRoc
Drives: GT86
I seem to be having the same issue. When you say move the latch down a touch what do you mean exactly?
Sent from my ONEPLUS A3003 using Tapatalk
DeaconRoc is offline   Reply With Quote
Old 05-21-2018, 06:43 PM   #8
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
Hood latches are bolted on and are able to be adjusted to get the correct height.
fx1mark is offline   Reply With Quote
Old 05-22-2018, 02:25 AM   #9
DeaconRoc
Drives: GT86
Mines on a Varis carbon hood and doesn't seem to adjust the same as oem on further inspection
Old 05-22-2018, 08:43 AM   #10
It should still use the stock latch doesn't it? Or does it use the pins?
The latch has slotted holes so you can adjust it.
The pins you adjust with the nut at the bottom.
Old 05-22-2018, 09:24 AM   #11
DeaconRoc
Drives: GT86
It uses its own latch which doesn't seem to be adjustable unfortunately
Old 05-22-2018, 09:33 AM   #12
The adjustable latch is what that part goes into. Should work exactly the same.
Old 05-22-2018, 09:49 AM   #13
DeaconRoc
Drives: GT86
Ah OK, thank you! From a quick look I'd seen that the oem hood looks like you can alter how far the U shaped piece that goes into the latch extends so I'd thought that was what was being suggested.
In terms of the adjustment is the aim to get the U shaped piece to go further into the latch? My hood is only sitting up on the one side (the passenger side on a left hand drive car)
Thanks again for all the help.
Old 05-22-2018, 09:58 AM   #14
By moving the latch down it pulls the hood down. If one side is up higher you will need to adjust the rubber stops on each side to even things out when the hood is closed. Remember to never slam the CF hood or those rubber stops will crack it.
HELP: hood pins/latches on carbon fiber hood scubie.brz Cosmetic Modification (Interior/Exterior/Lighting) 1 05-13-2016 12:10 PM
Florida: Trade Silver hood for Black hood 555 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2015 10:52 AM
Looking for vis aem hood or seibon fa hood ready to ship Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-29-2013 11:25 PM
