Drives: 2020 Toyota 86
Is this normal? New CAI, rpm fluctuation when braking to a halt.
Hi,
I installed a Grimmspeed CAI on my A/T 86 the other day. Maybe this is paranoia but after paying attention more I noticed that when braking at stoplights, as my RPM decreases to a certain amount <900, it fluctuates up a little bit, maybe from 750-850 as my speed decreases and I come to an idle. No clue if this happened before the install. I have no other issues, the car runs smoothly and my throttle response feels somewhat better. No lights on the dash, no sounds or anything abnormal I could think of. Pressing on the brakes at rest does nothing to increase RPMs. Is this just normal for the A/T for this car or after installing a new intake in general? For the record, I still am learning a ton and just getting into working on cars, so this probably sounds stupid. The one thread I searched didn't really give me an answer. Thanks |
Drives: brz 2017 hksv2
you have nt retuned and rescaled the maf against the new intake
this is what you get |
LMGTFY
Drives: 13 FRS, 91 Miata
Sell/Return intake.
Put stock one back on. Get better filter for the stock system. Problem solved, money saved. |
Ok.
So since I'm keeping it on, should I let the ECU adjust itself over time, reset it, or just open-flash tune it |
LMGTFY
Does OFT have a tune for that intake?
If yes, do that. If no. Custom tune. |
Drives: 2013 frs red
That's not much fluctuation. I wouldn't worry about it.
Drives: 2017 toyota 86
Normal
Grimmspeed doesn’t need MAF scaling it’s designed to mimic OEM. It can be optimized with a tune but by no means necessary. Don’t worry about it. |
Let the ECU learn. Were you running the AC or Heater? I notice the car will dip sometimes with heat and alot with A/C...
2013 Series 10 FRS #553
| Center for Automotive Safety calls for halt to recall | srt4evah | Issues | Warranty | Recalls / TSB | 29 | 04-03-2019 08:03 PM |
| Frs idle rpm fluctuation, vibration and fan/compressor noise, normal? | szjalo | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-06-2018 04:49 PM |
| Is this engine noise normal? (Consensus - normal) | StraightOuttaCanadaEh | Issues | Warranty | Recalls / TSB | 31 | 02-05-2018 03:01 PM |
| Is this normal? rpm drop when hard braking | szjalo | Issues | Warranty | Recalls / TSB | 11 | 02-23-2017 08:34 PM |
| I hear a rattling sound when braking in neutral with A/C on. Is this normal ? | awhatzable | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-21-2015 09:25 PM |
