Drives: 2014 Scion FR-S
Frs idle rpm fluctuation, vibration and fan/compressor noise, normal?
Hi all, very new here. I have a 2014 Scion FRS auto. recently noticed when the car is idling at working temperature with AC on, I can periodically (about every 7-10sec) hear the fan/compressor kicks in and makes a rather loud noise for couple secs. normally my car idles stably at 650rpm. whenever the compressor/fan noise comes alone, the rpm would jump to 900-1k, then quickly drops back within couple seconds, then repeat. Also a noticeable vibration on the steering wheel.
I brought my concern to the dealership but every time they tried to convince me this is normal. Is it really a normal phenomenon? Should this be regarded as rough idling? Thank you a ton in advance! |
| The Following User Says Thank You to szjalo For This Useful Post: | botbs (10-05-2018) |
Drives: 2013 FRS
Seems so. Mine also gets noisy at idle, and rpm sometimes drops to near 500 and back.
2013 FRS - JRSC CARB
"Use all of the track" they say |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
very normal....4 banger & not the heaviest flywheel..happens with MT too
#4 | |
![]() What your car is doing is quite normal. When the AC compressor engages, that puts an extra load on the engine and the engine increases in rpm to deal with the extra load (so it won't die). Then, the rpms settle back. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (10-06-2018) |
Drives: ‘13 FRS
Super normal. I thought my car was lugging at idle when I first got it.
not playing cards
Wait.
It has AC?
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Yes. A Ford Explorer waiting in a parking lot yesterday was doing exactly the same.
Compressor would kick every 7-10 sec keeping the defroster going. I thought it was weird because the V8 cycling sounded just like my boxer.
"I gotta rock." -- Charley Brown |
Drives: 2016 FRS
Hey, just wanted to pop in ask here instead of starting a new thread. I have my car tuned to OFT Stg2+ E85 and I also experience this same issue. I know the OFT is supposed to correct idle issues but I believe that may have been referencing it dipping and coming back. Is this normal for the OFT then as well?
#9 | |
Drives: 17 86
#10 |
Drives: 2014 BRZ Limited
It's normal.
How old is your battery? I ask because my rough idle smoothed out some when I replaced the garbage OEM battery. Mine used to stumble when I turned the headlights on, and the rough idle with A/C blowing was more pronounced when the lights were also on. After replacing the stock battery with an AGM, the extra stumble from putting a load on the alternator disappeared immediately. |
#11 | |
Drives: 2016 FRS
My battery is about 4 months old so I don't think it's due to that. Haven't tested it though... |
#12 |
#13 |
Drives: 2016 FRS
#14 | |
Drives: 2015 BRZ
https://www.ft86club.com/forums/atta...6&d=1386706237 |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| IDLE FLUCTUATION TSB.... | 5AD86D | Issues | Warranty | Recalls / TSB | 0 | 10-18-2016 07:55 AM |
| Idle dip ONLY with COMPRESSOR on | #87 | Issues | Warranty | Recalls / TSB | 2 | 11-14-2012 12:12 PM |
| Idle Fluctuation FIX | empower-auto | Issues | Warranty | Recalls / TSB | 2 | 09-14-2012 03:36 PM |
| A/C Compressor blowing hot? Is this normal? | SocalBurt | Engine, Exhaust, Transmission | 3 | 08-22-2012 08:10 AM |
