| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2014 Scion FRS
DIY: ARP Extended Wheel Stud Install
Drives: 2015 FR-S
You're creating good content, keep it up.
Agree it's all great stuff, though i've read a lot about damage caused using a hammer to knock out the hold studs and that you're better off with some kind of press instead.
Drives: Nevermorange FRS
A tool I didn’t know I needed but now have. Thanks
PRO86 | STL | LuckyDog
Drives: 2015 FR-S
You should throw on some latex/nitrile gloves when doing these videos. It looks more professional and cleanup is of course much easier.
| Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve | Jesse0923 | Brakes, Suspension, Chassis | 1 | 10-05-2016 12:48 PM |
| Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve | Jesse0923 | Wheels and Tires | 0 | 10-01-2016 09:50 PM |
| Extended stud thread conversion? 1.25 to 1.5? | Chicotunner07 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 06-05-2016 02:17 PM |
| P0500 after wheel stud install | theman233 | Issues | Warranty | Recalls / TSB | 3 | 05-21-2016 09:50 PM |
