Old 02-04-2021, 09:10 AM   #1
czellers
czellers's Avatar
Drives: 2K19 GT86
New Wheel Studs Question
So im running a +20 offset in the rear. On the stock studs ive got about.5" if stud to grab onto. Im going to replace the OEM with ARP studs, but cant decide between 1.75" or the 1.95" (i think the 2.535" would be way too long?)
On the front im at a +33 to clear the TRD SE Brembos.
The main thing I want to avoid is going too long stud wise in the rear that I have to do open ended nuts and then the front wont match.
czellers is offline   Reply With Quote
Old 02-04-2021, 09:26 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
1.95" will be enough. 1.75" is stock size.
I run the 2.5" with a 10mm spacer. You can fit a close ended but on with no spacer but they will be considerably longer.
Old 02-04-2021, 09:34 AM   #3
czellers
czellers's Avatar
Drives: 2K19 GT86
I run the 2.5" with a 10mm spacer. You don't need those, plus you need to do some trimming to the nipple on the stud to make it fit in the rear.
Ahh, i was just searching for the stock size to confirm.. Thanks!
What kind of trimming? so that the stud can be inserted from the rear without taking the hub off?
Old 02-04-2021, 09:47 AM   #4
RToyo86
RToyo86's Avatar
It is possible yes. I initially tried to remove the rear hub, but it was stuck on good. 2 winters put enough corrosion that they were seized on tight.
Post 12. I used a Dremel and cut off the ends, which allowed me to squeeze them in at a angle by rotating the hub. I've since cleaned them up further but no pic of the final result.
https://www.ft86club.com/forums/showthread.php?t=128354
The Following User Says Thank You to RToyo86 For This Useful Post:
czellers (02-04-2021)
Old 02-04-2021, 10:12 AM   #5
czellers
czellers's Avatar
Drives: 2K19 GT86
Nice, yea thats kinda what I was envisioning... my a 2019 so it should have only seen 1 possibly 2 real winters... im hoping for some good DIY luck..
Is there a min length of avail stud for the nut to sufficiently grab? or is it just a % of the total length of the stud that should be avail for the nut?
Old 02-04-2021, 09:38 PM   #6
Impureclient
Drives: 2015 FR-S
Copied this from an earlier post I made when I went through this:
The stock size are 1.70-1.75" depending on what brand you use. The ARP "stock size" is 1.75"(no nipple) and the 1.95"(nippled) is really the same thread but just has an extra .2" of nipple. I am using the 2.535"(nippled) ones which gives an extra 20mm total but minus the nipple about 15mm more threading to get a spacer in there. I'm only doing a 5mm spacer, possibly 10mm, but I'll still have enough room to use a closed end lug nut which is why I am not using the longest 3" ARP stud that most people use.
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
czellers (02-05-2021)
Old 02-05-2021, 08:36 AM   #7
czellers
czellers's Avatar
Drives: 2K19 GT86
Firstly I have 9.5" wide wheels.
Im running 5mm (as soon as they are delivered) spacers on the front with +38 offset and +20 in the rear. I really love the 9.5" wide and +20 mm setup in the rear. Ill snag some pictures later today.
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes Pat Tracking / Autocross / HPDE / Drifting 86 07-16-2021 10:50 AM
Shaving wheel studs question ABGHUNTER_86 Scion FR-S / Toyota 86 GT86 General Forum 4 01-15-2020 10:04 PM
Wheel Studs IceFyre13th Arizona 8 03-11-2017 08:05 PM
WTB WHEEL STUDS TomShugoy Want-To-Buy Requests 0 02-08-2016 06:44 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 08:31 AM
