Old 02-03-2021, 02:27 PM   #1
lumbeardjack
lumbeardjack's Avatar
Drives: 2017 Toyota 86
ACDelco Platinum spark plugs, will they fit?
I got ACDelco Platinum spark plugs and I got a bit nervous when the only viable reason behind which ones to get was the salesperson said "I used to have a BRZ years back and this is what I used" (good memory???)
I purchased part# 41-805 and when I scour the web I see nothing saying that it would fit my 2017 86. the owner's manual says to strictly use Iridium and I found a thread that mentioned a platinum plug that can be used. I'd like some clarity before I jump into this
lumbeardjack is offline   Reply With Quote
Old 02-03-2021, 03:29 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You'll likely be a martyr. or you can choose not to take the risk. I personally spend the coin to get OE plugs, because sparkplugs on this car are not something worth messing around with
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
churchx (02-04-2021), Lantanafrs2 (02-04-2021), Plumbus (02-04-2021)
Old 02-04-2021, 06:08 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I don't know if our OE sparcplugs are already rather expensive and higher end due wish to lengthen change intervals (by original procedure involved lifting engine), or it's generic trait of modern high efficiency/rpm/compression engines that need high quality plugs as well, but OE are good. Most aftermarket ones claiming massive improvement over those i'll look at as if snake oil. Or at very least as massively overblown improvement, if any. OE in this case works well, and at most i'd think of trying to find them somewhere cheaper, with lesser markup then that of some dealerships. Coilpack of very early twins is different story though.
Old 02-04-2021, 07:16 AM   #4
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
OEM spark plugs are DENSO Iridium. Iridium is harder, lasts longer, & has higher melting point than Platinum. Changing our boxer's spark plugs is quite challenging too so stick with the OEM Iridum ones.
Subaru – 22401AA801
Subaru – 22401AA800
Toyota/Scion – SU003-04931
Toyota/Scion – SU003-00416
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
The Following User Says Thank You to sygfrid For This Useful Post:
soundman98 (02-11-2021)
Old 02-04-2021, 08:43 AM   #5
TommyW
TommyW's Avatar
Drives: '13 Whiteout
When I had my new IAG motor built I asked my builder what plugs and he said to stick with OEM
The Following User Says Thank You to TommyW For This Useful Post:
Old 02-04-2021, 04:21 PM   #6
Purist
Purist's Avatar
Drives: Subaru BRZ
Dont forget that incorrect sparkplug temperatute range can cause knocking, whuch will cause power loss at best, damage at worst.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 02-06-2021, 12:46 AM   #7
jflogerzi
jflogerzi's Avatar
Oem in this case is good. Stick with them. Given how long they last...
2013 Series 10 FRS #553
Old 02-10-2021, 05:27 PM   #8
8inchAzN
Drives: Car
What Iridium spark plugs would you recommend?
Edit: wait are you using DENSO Iridium and Iridium interchangeably? I read it as Iridium > OEM Denso Iridium and you continued to recommend the Denson Iridium...
8inchAzN is offline   Reply With Quote
Old 02-11-2021, 12:32 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
Iridium is name of metal, not some trademarked product. And what's wrong with using OE recommended plugs that had been chosen by engineers that made this engine and have most experience with it? About the only reason not-to, if you have reliable info (apart from advertisement pitch by manufacturer or retail to push sale or some single forum thread) that some aftermarket alternative is as reliable and not differing much in important specs, but still is cheaper then OE.
Old 02-23-2021, 05:56 PM   #10
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I have been running HKS sparkplugs for a little over two years now. I haven’t had any knocking or other strange noises coming from under the hood.
scion fr-s is offline   Reply With Quote
OEM Spark Plugs - NIB JohnPayneFun Mechanical Maintenance and Tools 2 04-20-2020 03:03 PM
spark plugs Legend@wheels Engine, Exhaust, Transmission 3 12-12-2018 12:13 AM
How to gap spark plugs Strife26 Engine, Exhaust, Transmission 38 01-09-2018 01:06 AM
Spark Plugs at 65K user4815 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-25-2017 04:19 PM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
