Old 01-28-2021, 03:23 PM   #1
oziel
Drives: 2015 Subaru BRZ
Electric Power Steering Parts
Does anybody know if the BRZs power steering components are the same as those that the FRS and gt86 use? Im looking for a power steering column, i have a BRZ just wondering if I could get the part out of a FRS.
oziel is offline   Reply With Quote
Old 01-28-2021, 07:37 PM   #2
pope
has a funny hat
Drives: 2014 BRZ Limited
you shouldn’t have a problem between 86/FRS and BRZ. The inner shaft is different between key ignition and push start cars though.
pope is offline   Reply With Quote
Old 01-28-2021, 09:45 PM   #3
ermax
ermax's Avatar
They are the same. Just curious, why you are replacing it?
Old 01-28-2021, 10:12 PM   #4
oziel
Thank you. And as of why I am replacing it, the steering on my car got really heavy and stiff. Ive checked ball joints, tie rods, suspension, fuses, the module, rack and pinion and everything looked good. Im not sure what else it could be...
Old 01-28-2021, 10:12 PM   #5
oziel
Thank you
Old 02-01-2021, 03:18 PM   #6
ermax
ermax's Avatar
There is a torque sensor in there that detects your inputs so it knows how much assist to give. I could see that causing issues if it was bad. There is also a calibration process you can go through in Techstream that may help.
Search Amazon for "Techstream" and you will find a bunch of cables that work with Techstream. I got one for $18 but it looks like the average price right now is about $30. If you aren't familiar with Techstream it is the official Toyota software used at the dealership. It does diagnostics, pairs keys, key fobs, changes dealer settings like the stupid seatbelt warning, DRL toggle, ect. It will also do real time data logging with a very high sample rate. It will works on the FRS/86/BRZ.
Electric Power Steering (EPS) noisy RevoG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 144 10-01-2023 03:25 PM
Electric Power Steering oziel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 01-24-2021 01:06 AM
Recall for Electric power steering (EPS) tm86 AFRICA 36 05-16-2017 07:04 AM
Electric Power Steering ArtS Electronics | Audio | NAV | Infotainment 0 10-31-2016 08:19 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
