Old 01-17-2021, 08:43 PM   #1
itzaustin
Drives: 2013 FRS 10 series
Starting issues after clutch install.
Hey all just got a quick question to see if anyone possibly had an idea. So just finished up on installing a new flywheel, clutch fork and pivot into the car. Second time I’ve done transmission work on it. Got everything back together fine, started up the very first time no issues at all to test everything out and it started up and worked fine. Parked it double checked around for stuff noticed the two wires on top of the trans weren’t plugged in so I plugged them in. Went to start the car up again after and nothing. No crank no start no clicks. Only similar issues that sounds like this is the clutch switch going bad causing the car not to start. I’m going to order one and go from there. But if anyone has some insight go ahead and let me know!!! Thank you
itzaustin is offline   Reply With Quote
The Following User Says Thank You to itzaustin For This Useful Post:
humfrz (01-17-2021)
Old 01-17-2021, 09:27 PM   #2
e1_griego
e1_griego's Avatar
Drives: Many
Loose battery terminal?
Two plugs on top of the trans are for switches I think -- reverse switch and one other.
edit: other is neutral switch.
e1_griego is offline   Reply With Quote
Old 01-17-2021, 11:29 PM   #3
Ashikabi
Ashikabi's Avatar
You should be able to test the clutch switch with a multimeter easily. Seems too coincident with the work you just did. I'd lean more towards something in/around the transmission tunnel
Old 01-17-2021, 11:59 PM   #4
humfrz
Bubba suggests to unplug those two wires -
Old 01-18-2021, 11:39 AM   #5
czellers
czellers's Avatar
Drives: 2K19 GT86
Is it possible you plugged those two wires in the wrong place (reversed the connections?). Maybe swap the wires and see if you still have the same issue(s)?
czellers is offline   Reply With Quote
Old 01-18-2021, 02:07 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The plugs are keyed differently. You would have to go in there and cut the tabs off the plug to make them interchange.
Old 01-18-2021, 02:24 PM   #7
czellers
czellers's Avatar
Drives: 2K19 GT86
I figured, I was looking for some spec sheets/docs to prove it.. pictures of the harness on ebay etc its hard to tell.
Next thing I would try it disconnecting the battery, and re-seating those connections, then reconnecting the battery and trying...
Old 01-18-2021, 02:28 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I just went out and looked at my spare trans to verify. Black plug has tab on left(looking at trans from the front), brown plug has tab on the right.
Old 01-18-2021, 08:20 PM   #9
itzaustin
Yea tried unplugging those again that were off prior to the issues and there is no change in starting, as well as disconnecting battery re seating them and then trying again. The one thing that just throws me off is the fact that it started once already, and then it won’t start again. When I hit the push to start the console screen as well as my gauges turn off and back on as if it was actually starting like normal.
Old 01-18-2021, 08:33 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Have you checked or jumped the clutch switch?
Old 01-19-2021, 02:15 PM   #11
czellers
czellers's Avatar
Drives: 2K19 GT86
So, have you tried unplugging those two and trying to start it again while leaving them unplugged (same circumstance as when it started the first time?)
Old 01-20-2021, 04:38 PM   #12
Grady
Grady's Avatar
Sounds like dead battery?
Newly Built FA20 - Vortech - e85 - Starting Issues Gopherboy6956 Forced Induction 2 05-27-2018 11:35 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Intake or battery issues with winter starting daiheadjai BRZ First-Gen (2012+) — General Topics 10 01-20-2016 06:25 PM
Issues starting Scalzo Forced Induction 98 07-16-2014 01:15 PM
Clunk sound after starting car and releasing clutch subiestyle Issues | Warranty | Recalls / TSB 1 03-14-2014 03:30 AM
