Drives: 2017 BRZ MT, 2009 Civic sedan AT
I am using Nutec NC-51 0w-30 engine oil, and the oil cooler is HKS S Type for 86/BRZ.
Attached images are the results measured using two gauges under the same other conditions. I believe in the accuracy of defi as an industry benchmark, so it seems that the measurement results of Shadow Pro3 are not accurate and the price is not cheap. Has anyone done a similar comparison? How is the result? Last edited by qiumaoyuan; 01-25-2021 at 12:55 PM. |
Rust bucket enthusiast
Do you have the sensor connected in the same location?
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
Well as you'd alluded to, the sender is likely designed or functioning poorly in one of them. I'd send the one you trust less back for a refund and include your findings to them.
Use the one with higher oil pressure. Car wont care, you will feel better!
Drives: UK GT86
Only about 5 Bar in it, probably not that far outside of tolerance on sensors between the 2. Both give you a good indication of the pressure, TBH both are in the ballpark of the pressures I'd expect.
.: Stealth 86 :.
| Tags |
| defi, oil pressure, shadow |
| oil pressure gauge | onemorelap | Engine, Exhaust, Transmission | 69 | 03-04-2023 05:46 PM |
| AEM Oil Pressure Gauge | Chumblebee | Audio/Visual, Electronics, Infotainment, NAV | 1 | 06-11-2018 11:15 PM |
| Oil Pressure Gauge | solidONE | Engine, Exhaust, Transmission | 59 | 04-03-2018 04:15 PM |
| AEM Oil temperature gauge and pressure gauge with pods. | mtsound | Engine, Exhaust, Bolt-Ons | 2 | 08-24-2017 12:55 PM |
| Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 12:48 PM |
