Old 01-06-2021, 04:32 PM   #1
czellers
czellers's Avatar
Drives: 2K19 GT86
A-Pillar Question
How do I detach/remove that red clip in the pictures?
czellers is offline   Reply With Quote
Old 01-06-2021, 04:37 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I have to ask- what are you doing that necessitates removing it completely? I understand if you're painting it or something. I poked at mine for a few minutes and ended up just not wrapping my pillars ( was going to do suede wrap like I did in my e36) but gave up because it wasn't simple and I didn't want to be force-fed the top of the A-pillar cover if that curtain bag went off.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 01-06-2021, 04:40 PM   #3
czellers
czellers's Avatar
Drives: 2K19 GT86
triple a pillar gauge pod. Ill eventually be removing that air bag. today i was just popping off the current pillar to have a look around.
Old 01-06-2021, 05:26 PM   #4
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Is that strap on there to prevent the trim from becoming shrapnel in the event of an airbag deployment?
If so, I suspect the ends of the strap are attached very securely . . .
LimitedSlip is offline   Reply With Quote
Old 01-06-2021, 06:00 PM   #5
czellers
czellers's Avatar
Drives: 2K19 GT86
Well yea, the length of the red piece would (fully extended) represent the max travel the a-pillar would have from its clipped in position in the event of a deployment, but the plan is to remove the bag.. first car ive ever had with side curtain airbags.
My thinking was it might be as simple as a quarter turn of the mounting point or something... but i didnt want to try it and snap it (yet) in the event there was a simple method or a service manual somewhere..
Old 01-06-2021, 08:33 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
nnnnooooOOOOoooo
Old 01-06-2021, 08:52 PM   #7
spike021
spike021's Avatar
I was considering A-pillar pods a few months back, ended up deciding against it. All the options seemed obstructive to visibility on top of being problematic due to the airbag inside that pillar.
Good luck, though.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 01-06-2021, 09:02 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Good luck, though.
To me, a pillar gauges are so other people can see you have gauges
I love this setup, much less intrusive then my Perrin two gauge setup that blocks part of the cluster.
https://www.ft86club.com/forums/show...&postcount=364
Old 01-06-2021, 09:03 PM   #9
DarkPira7e
DarkPira7e's Avatar
I'm afraid of them after snapping my pinky finger on one. In my 3000gt VR4 it hung very close to the steering wheel (you could touch the windshield with your fingertips, very horizontal roof line). In a fit of excitement, I turned the wheel clockwise to make a tight corner quickly and nearly went off the road after my left hand pinky got caught on it.took months for it to bend correctly again. It still looks f'd up.
A constant reminder to myself that nothing should dangle from rearview mirror, nothing should be near the steering wheel, nothing should be between your hand and the shifter. Because as soon as it's out of place, that's the one time you really might need to be unencumbered!
Old 01-06-2021, 09:14 PM   #10
spike021
spike021's Avatar
That's a great setup and what I was considering as well.
Old 01-06-2021, 09:14 PM   #11
spike021
spike021's Avatar
That sounds nearly as painful as when I severed a tendon in one of my index fingers once. It also took a couple of months to heal and be able to bend straight again (plus physical therapy even).
Old 01-07-2021, 08:40 AM   #12
czellers
czellers's Avatar
Drives: 2K19 GT86
Theres some degree of 'showmanship' in every mod you do, (think carbon fiber front splitters or those big massive rear diffusers as 2 big ones). For me personally, I like the look and positioning. But between it NOT being a daily and the illegal tint, nobody will likely ever see the gauges I have, so I would say swing a miss on that theory as it pertains to me specifically. Other people though, I suppose its possible.
The picture you included is done nicely, its just too damn 'cluttered' for me. I want to run oil pressure, boost, and a nice wideband AFR. And the ones I've seen where people have them mounted on the passenger side above the glove box is straight up cringey.. (kinda like lil bow wow's VW in Tokyo Drift or some of that pimp my ride shit where they bondo the whole interior)
Old 01-07-2021, 12:29 PM   #13
JCW 86
JCW 86's Avatar
Drives: 2013 Raven FR-S
If you're looking for another option, you should check out Block8head. He makes a double and triple pod setup that drops into the defroster vent.
https://www.block8head.com/
Personally, I don't like his triple setup since it seems too large and would run the double setup with an ATI AC vent pod to run three gauges.
JCW 86 is offline   Reply With Quote
Old 01-07-2021, 01:14 PM   #14
spike021
spike021's Avatar
The Block8head single pod is what I went with.
Two issues though:
* order to delivery was around 3 months and if you go on his FB page, there are people who have been waiting even longer who have to poke and prod him to remind him of their order (typical for one-man production shops like this)
* the hole access for the cables wasn't large enough for mine and caused the cables to keep hitting the interior vent tube (not sure what else to call it) and the only way to make the cables fit without getting squashed was to enlarge the access hole ourselves. _Maybe_ fancier routing would've helped, but the way we did it it just wouldn't work otherwise.
Removing A-Pillar completely (green plastic retainer question) Suparu Cosmetic Modification (Interior/Exterior/Lighting) 4 03-13-2020 05:23 PM
How do you remove the C-Pillar? lupindub Scion FR-S / Toyota 86 GT86 General Forum 15 09-20-2015 10:23 AM
Pillar Removal? kmbkk Electronics | Audio | NAV | Infotainment 2 07-12-2015 11:55 AM
Almost Touching... Pillar!!! Choco BRZ First-Gen (2012+) — General Topics 26 06-26-2015 04:17 PM
C-Pillar Airbags rlpaul Cosmetic Modification (Interior/Exterior/Lighting) 1 05-09-2015 01:19 AM
