Old 03-12-2020, 09:06 PM   #1
Suparu
Drives: 2013 BRZ Limited
Removing A-Pillar completely (green plastic retainer question)
I have a rattle from behind my passenger side A-pillar, I’d previously put weatherstripping on the bottom of it and it helped buy something behind it is causing the rattle. I tried to remove the plastic green retainer but couldn’t so I left it attached.
So I need to completely remove the a-pillar this time, remove that plastic green retainer. But I’m concerned about setting off the airbag (I’ll disconnect the battery for 30 mins first) and also not being able to get that green plastic retainer back in place.
I found this post with was helpful
https://www.ft86club.com/forums/showthread.php?t=54683
Has anyone ever removed the pillar before, any advice on how to deal with the green plastic retainer?
Suparu is offline   Reply With Quote
Old 03-12-2020, 09:21 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Why worry about the green leash? Just swing the a-pillar plastic around with it connected until you've fixed whatever your noise is. The leash is just to prevent you getting hit by the plastic if the curtain airbag goes off.
I've removed my a-pillar and put it back without undoing the green leash
Old 03-12-2020, 10:15 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Agreed, and I was specifically doing this to apply foam filler to remove a rattle too.
Old 03-13-2020, 01:22 AM   #4
makinen
makinen's Avatar
Drives: Toyota 86
As written in that link, turn 90 degrees. Then eventually you'll get it done.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 03-13-2020, 06:23 PM   #5
RickyBobby
Drives: 2013 Firestorm FR-S AT
I had to remove the panel completely to run my rd's power wire to the 12V socket. The green plastic retainer is a bitch to remove and replace. I used needle nose pliers to turn it 90 degrees. DO NOT remove it if you don't have to.
RickyBobby is offline   Reply With Quote
The Following User Says Thank You to RickyBobby For This Useful Post:
Suparu (03-16-2020)
Removing Passenger Side Pillar Mcdj18 Cosmetic Modification (Interior/Exterior/Lighting) 6 10-29-2016 04:39 PM
A/C completely shut off... Scikotic Issues | Warranty | Recalls / TSB 6 08-01-2015 05:28 PM
How To Completely Rebadge Your FR-S tbwoodlee Cosmetic Modification (Interior/Exterior/Lighting) 62 05-08-2015 12:55 AM
