Old 01-05-2021, 01:50 PM   #1
touko
Drives: 2017 Toyota 86
Auto-off dome light
This is the second time I've drained the battery with leaving the dome light on my 2017 86. Does anyone know if there is a good way to make this turn off after a while?
What I noticed btw is the headlights have auto-off when on auto position, where simply locking with remote will trigger a timer, and another press to turn off the lights. I wonder if there are some signals that can be used for controlling dome lights..
touko is offline   Reply With Quote
Old 01-05-2021, 02:06 PM   #2
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Dome light can be put on Door mode. Move/slide the switch to Door and you won't have any issue after locking the car as it will switch off after like 10 seconds.
Also change the bulb to a led one.
Problem solved.
Thefalls is offline   Reply With Quote
The Following 8 Users Say Thank You to Thefalls For This Useful Post:
DarkPira7e (01-05-2021), HKz (01-05-2021), ichitaka05 (01-05-2021), Jdmjunkie (01-05-2021), ls1ac (01-05-2021), soundman98 (01-05-2021), spike021 (01-05-2021), x808drifter (01-05-2021)
Old 01-05-2021, 02:34 PM   #3
9walker
9walker's Avatar
Drives: Toyota 86
Led is your answer. I left it on the whole day then drove away like nothing happened.
Sent from my SM-G975F using Tapatalk
9walker is offline   Reply With Quote
Old 01-05-2021, 04:30 PM   #4
touko
Problem solved.
Mine is on Door mode 99% of the time. The problem is when I switch it to On for something then forget to switch it back to the Door before I get out.
I’ll look into LED lights regardless. Thanks for the suggestion!
Old 01-05-2021, 04:47 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This is what keeps AAA in business. Try your best to be cognizant, but we all do it.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 01-05-2021, 10:13 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
mine doesn't work that way. if i left it on, the battery would definitely be dead.
there's cheap low power led, and there's expensive led
Old 01-08-2021, 09:14 AM   #7
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
"All"
First thing I've done in my last few cars is turn the dome light off. It's attracts bugs in the summer time and I hate bugs more than anything.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Dome light nguyen.tommie Cosmetic Modification (Interior/Exterior/Lighting) 1 11-05-2019 10:52 AM
Underglow/footwell light controlled by door without using dome light or door switch pcguru2000 DIY (Do-It-Yourself) Guides 5 06-17-2018 11:09 AM
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 09:39 PM
Dome light very low power???? lbroskee Electronics | Audio | NAV | Infotainment 2 03-15-2014 02:03 PM
