Old 01-05-2021, 10:45 AM   #1
czellers
czellers's Avatar
Drives: 2K19 GT86
E85 Conversion
So I have a half tank of fuel left and I seem to see a fair bit of stations around me with the "may contain 10% ethanol" disclaimer and Im thinking its throwing my fuel trims out of whack, the picture is yesterday after warming up and driving for about 25 min.
I have a catless EL header, catless overpipe/frontpipe/exhaust
I'm thinking about converting permanently to E85, but I'm wondering if there's any drawbacks, especially since its not a daily driver for me?
czellers is offline   Reply With Quote
Old 01-05-2021, 11:31 AM   #2
pallen
pallen's Avatar
Drives: 2017 Toyota 86
I'm a big fan of the FlexFuel. E85 is fairly available where I live, but I've gone to stations and they've been out, or on a road trip and can't find an option. It's nice to know I can run a tank of 91 if I need to and the system will adapt.
pallen is offline   Reply With Quote
The Following 3 Users Say Thank You to pallen For This Useful Post:
Irace86.2.0 (01-05-2021), Plumbus (01-05-2021), x808drifter (01-05-2021)
Old 01-05-2021, 11:42 AM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
10% ethanol isn't enough to do that to fuel trims. Check your intake and exhaust for leaks
Drawbacks?
  1. E85 from the pump can vary anywhere between 51% to 83% ethanol. Worst case, a fixed content tune can run quite rich and have some knock risk if the E% is low and the engine is expecting higher E%/Octane
  2. You state you don't drive the car much. Ethanol tends to absorb water over time, which is bad for fuel that sits in tank for long periods of time
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
czellers (01-05-2021)
Old 01-05-2021, 11:49 AM   #4
czellers
czellers's Avatar
Drives: 2K19 GT86
So you have the flexfuel sensor installed then?
i'd be using the OFTv2 to flash the e85 tune and back (if needed).
Old 01-05-2021, 12:00 PM   #5
czellers
czellers's Avatar
Drives: 2K19 GT86
Drawbacks?
RE: exhaust leaks... Is the best/full-proof method for doing this just placing your bare hands over each flange/joint and feeling for any blow outs and a visual or any obvious holes?
Old 01-05-2021, 12:16 PM   #6
pallen
pallen's Avatar
Yes, I have the sensor installed and a tune that goes with it.
Old 01-05-2021, 12:49 PM   #7
DarkSunrise
DarkSunrise's Avatar
24 percent LTFT is definitely odd. Something is going on with your tune or hardware. Would definitely fix that before moving to E85. I found the easiest way to check for exhaust leaks was to pull the gaskets and see where the soot is collecting or feel around the flanges.
These days I’ve only been using my e85 frs on weekends. Because OFT’s e85 tune will take a few cranks to start in colder weather, you should make sure your battery is strong. Also top off your tank before parking it for long periods of time (to minimize the air in the tank from which it can draw moisture).
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 01-05-2021, 01:05 PM   #8
czellers
czellers's Avatar
Drives: 2K19 GT86
Someone had previously asked in another thread about the ethanol content of the gas im currently running. I go to sheetz which is heavily frequented so they should be cycling through their supply regularly but on the pump it does say may contain 10% ethanol... i have a feeling the fuel im buying is having an impact on my LTFTs....
Old 01-05-2021, 01:07 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Most fuel contains around 10% ethanol.
Old 01-05-2021, 02:09 PM   #10
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
^^^ This. I have seen around 6-10% ethanol from pump gas. It shouldn't be an issue at all, as most aftermarket and all factory tunes/components are designed around this fact.
Run flex fuel and not a static tune. E85 can vary a lot depending on the station/source and time of year and geography, and like others have said, you may need to add pump gas to a tank if you find yourself away from an E85 station.
Old 01-05-2021, 03:15 PM   #11
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
I would never run e85 without a flex fuel kit installed. just the peace of mind is worth every last penny, not to mention you will get the most of the ethanol with a custom tune for it.
Plumbus is offline   Reply With Quote
Old 01-05-2021, 06:09 PM   #12
Turdinator
Señor Member
Turdinator's Avatar
Do you have an intake installed?
1974 TA22 Celica
2013 86 GT
Old 01-05-2021, 11:51 PM   #13
jflogerzi
jflogerzi's Avatar
Agree with others. Get your fuel trims in line first. And I would rather ditch oft for ecutek and a flex fuel setup. Well worth it IMO.
2013 Series 10 FRS #553
Old 01-06-2021, 09:36 AM   #14
czellers
czellers's Avatar
Drives: 2K19 GT86
I have one (Skunk2 powerbox) but i havent installed it yet. its got some kind of aftermarket filter, but i need to snag a K&N or something and see if it makes a difference in the LTFTs first maybe..?
Anyone here used this Hub conversion? jay1989 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-19-2014 10:33 PM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
E85 conversion ender2664 Engine, Exhaust, Transmission 6 09-15-2013 10:58 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 02:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
