Old 12-23-2020, 07:01 PM   #1
holeeray
holeeray's Avatar
Drives: 2015 BRZ Limited
Couldn't get front toe set because of worn out tie rods?
So I got some winter tires put on today and asked for an alignment and the shop said they couldn't get my front toe settings to 0 because my tie rods were worn out? I've never heard of this, but is this something worth upgrading or should I just get OEM replacements?
Bone stock
holeeray is offline   Reply With Quote
Old 12-23-2020, 07:03 PM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
It’s common wear and tear for tie rods to go. Yes, when they’re worn out, the tech will have a hard time setting the toe. Replace your tie rods.
Drifter X is offline   Reply With Quote
The Following User Says Thank You to Drifter X For This Useful Post:
holeeray (12-23-2020)
Old 12-23-2020, 07:35 PM   #3
holeeray
holeeray's Avatar
So I'm considering these to replace the inner tie rods:
https://meganracing.com/suspension/t...ms/mrs-sc-0660
Also considering these:
https://www.ftspeed.com/part/kca435-...fr-s-2013-2014
However, it seems the whiteline roll center kit is more for lowered cars whereas the suspension I've bought is only going to lower my car by less than an inch. Should I just stick to OEM?
Bone stock
Old 12-23-2020, 07:37 PM   #4
Drifter X
Drifter X's Avatar
Yeah I would go with OEM. But that’s my opinion though.
Old 12-23-2020, 07:45 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
holeeray: i'd think of those Megan tie rod ends only for need of slightly more steering angle .. and with some wheel/tire widths you may get rubbing when steered to lock
The Following User Says Thank You to churchx For This Useful Post:
Old 12-24-2020, 03:41 PM   #6
jflogerzi
jflogerzi's Avatar
Whiteline makes good stuff.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
holeeray (12-28-2020)
Old 12-24-2020, 04:08 PM   #7
strat61caster
strat61caster's Avatar
Sounds like a lazy/greedy shop to me. Almost 100k miles on my 8 year old hooptie and the tie rods are fine.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
holeeray (12-28-2020), Lonewolf (12-29-2020)
Old 12-24-2020, 04:24 PM   #8
norcalpb
norcalpb's Avatar
I replaced my tie rods at 150k but if I could do it again I would replace the whole steering rack, as that comes with the new tie rods. $380 vs $150 or something like that.
The Following User Says Thank You to norcalpb For This Useful Post:
Old 12-24-2020, 05:17 PM   #9
Grady
Grady's Avatar
If you are lowered, go with the Whitline. If not OEM or quality aftermarket.
The Following User Says Thank You to Grady For This Useful Post:
Old 12-28-2020, 09:32 PM   #10
wparsons
wparsons's Avatar
If it's never been aligned, there's a good chance they could be seized and the shop didn't want to remove them or heat them to unseize them.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 12-28-2020, 10:32 PM   #11
holeeray
holeeray's Avatar
Yeah, I'm starting to feel this may have been it. I've got 36k on mine. They didn't even offer me a printout to see where my alignment was, just said that the toe "wasn't that bad".
Bone stock
The Following User Says Thank You to holeeray For This Useful Post:
strat61caster (12-29-2020)
Old 12-28-2020, 11:25 PM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
if your tie rods are worn out at 36k miles, you're going to have a bunch of other suspension related problems. jump any creeks lately?
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
holeeray (12-29-2020), strat61caster (12-29-2020)
Old 12-29-2020, 11:55 AM   #13
strat61caster
Wtf you got ripped off.
ineedyourdiddly
Old 12-29-2020, 12:49 PM   #14
norcalpb
norcalpb's Avatar
You joke but a friend of mine did that in his Toyota and hurt his wheel bearings.
So hurt they were rotating at such an off-angle that the spokes of the wheel were smacking against the brake caliper!
soundman98 (12-29-2020)
Devsport front splitter with rods frs/brz cjm86 Exterior Parts (Aero, Lighting, Etc.) 23 05-28-2017 04:05 PM
APR FRONT SPLITTER with RODS davidshu0327 Exterior Parts (Aero, Lighting, Etc.) 20 03-10-2017 03:03 AM
APR front splitter w/ rods APR SIDE MIRROR BRZtoni Exterior Parts (Aero, Lighting, Etc.) 26 02-24-2017 02:28 PM
WTB APR splitter+rods and 5:AD front lip Packofcrows Want-To-Buy Requests 1 07-06-2015 11:15 PM
FS: NJ, APR Front Splitter w/ Rods jaydee_do_work Exterior Parts (Aero, Lighting, Etc.) 4 01-25-2014 12:59 PM
