Old 12-16-2020, 11:08 AM   #1
02maher
02maher's Avatar
Drives: Gt86 2013
Cluster swap not cross-checking
Hello 👋🏽
Is it possible to swap a speedometer with a used one. I tried to do a « hand shake » with the techstream registering the communication ID but it doesn’t work and shows this message « Unable to cross-check with the meter/SCU ECU... please refer to the repair manual »
Thing is I had to swap my starting system and now I’m trying to at least have my original speedometer as it has the correct mileage in kilometers.
02maher is offline   Reply With Quote
Old 12-17-2020, 11:00 AM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I have used kouki 86 cluster gauge in my zenki BRZ. Working without an issue
Old 12-17-2020, 04:12 PM   #3
gpvecchi
gpvecchi's Avatar
Keyless cars don't need cluster pairing, just cars with physical keys. For the first ones, just swap the clusters, regarding the second ones I have no experience, as not available in Europe.
BTW, the only way to restore Km is to desolder a chip. If the clusters come from same MY you can just swap the chips, otherwise you need someone to recode the chip.
gpvecchi is offline   Reply With Quote
Old 12-17-2020, 10:32 PM   #4
02maher
02maher's Avatar
Drives: Gt86 2013
Yeah my car isn’t the keyless version and the cluster that I have now is digital, unlike my original... So in this case my understanding is that the only way is to reprogram it right?
Old 12-18-2020, 03:09 AM   #5
gpvecchi
gpvecchi's Avatar
If you have the 2017+ version with LCD display, it's specific for the keyless, I don't know if it will work on non keyless...
Old 12-18-2020, 03:21 AM   #6
02maher
02maher's Avatar
Drives: Gt86 2013
No I have the 2013 model... both mine and the swapped one, differences are that my original is not digital and is in kilometers.
Old 03-31-2024, 03:05 PM   #7
SAWYER
SAWYER's Avatar
Drives: 2013 Scion FR-S (Base)
Any updates on this? Currently swapping my 2013 FRS Cluster with another one. (also from a 2013 FRS)… On Techstream when I attempt to do the handshake procedure I run into “Error ECU Communication ID Registration … Unable to cross-check with the meter / SCU ECU. Please refer to the repair manual.
SAWYER is offline   Reply With Quote
cluster, immobilser, meter, odometer, speedometer
DIY - Gauge Cluster LED swap Blackrsx DIY (Do-It-Yourself) Guides 216 11-04-2021 10:40 AM
Swap TRD (Limited) LED dash gauge cluster into base 2017? Scremin@ATS Cosmetic Modification (Interior/Exterior/Lighting) 7 03-26-2019 10:07 AM
Used gauge cluster swap hachi roku [86] Electronics | Audio | NAV | Infotainment 0 09-23-2018 06:26 PM
LED Swap on Instrument Cluster Lickwid Apex Cosmetic Modification (Interior/Exterior/Lighting) 1 01-25-2018 02:38 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
