Old 12-01-2020, 03:57 PM   #1
Rambo305kid
Drives: 2013 Scion frs
High squealing/grinding noise when driving
Ok so I’ve researched and put in a lot of wrench time to figuring this out. It’s driving me crazy!! Please help me.
When I drive at 4K rpm I get a grinding noise or squealing. Listen to the video. I replaced every pulley on the car with nst pulleys, thinking my pulleys were beat and it needed to be replaced. Mind you I’m at at 94k miles. I’ve also replaced the belt to also eliminate that. Still had same issue. Figured ok
Well maybe the bearings inside the alternator is going bad as well. Bought a remanufactured alternator and the car is still giving me this issue. What could I be missing? It’s only when I drive a live 4K and keep it there will
You here this noise.
Rambo305kid is offline   Reply With Quote
Old 12-01-2020, 04:04 PM   #2
Rambo305kid
can’t upload video so posted on YouTube
Old 12-01-2020, 05:56 PM   #3
ls1ac
ls1ac's Avatar
Can the sound be duplicated while parked and someone else holding the accelerator at that RPM?
Will it happen at that RPM in most gears?
Old 12-01-2020, 06:14 PM   #4
HaXx
Drives: jrsc_brz
are you aware of the throw out bearing issue with the 2013"s and have you considered/researched that as a culprit. is the sound ever present at startup when the motor is warming, or only present when the car is moving at 4krpm. the TOB issue is a similar sound, but the sound can be manipulated drastically by depressing the clutch pedal in and out.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 12-01-2020, 06:21 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
tap your foot on the clutch pedal, just a touch while it's happening.
Old 12-01-2020, 06:38 PM   #6
Rambo305kid
I replaced my clutch wi to act hd at 86k with verus forged fork and billet act throw out bearing to.
Old 12-01-2020, 06:38 PM   #7
Rambo305kid
It happens at any gear only when driving. When it’s neutral it doesn’t do it
Old 12-02-2020, 12:31 AM   #8
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
When I had my ACT clutch, it would sometimes squeal around that rev range. It would go away if I put a little pressure on the clutch pedal. May just be the clutch tolerances/something vibrating
EndlessAzure is offline   Reply With Quote
Squealing noise coming from pulley White142 Issues | Warranty | Recalls / TSB 21 08-05-2020 01:03 PM
Odd Squealing Sound When Driving effigy Issues | Warranty | Recalls / TSB 2 10-10-2019 06:46 PM
Grinding noise when AC on Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 07-11-2016 01:25 AM
Shifting at high RPM - Grinding Magzter Issues | Warranty | Recalls / TSB 16 12-05-2014 01:24 PM
Clutch grinding when driving? J-Money Issues | Warranty | Recalls / TSB 0 08-12-2014 03:22 PM
