Drives: slowly getting there
how close is too close?
not sue if this should go into the wheel categories or suspension. right now I have Bilstein b 14 coils and a 18x9.5 +35 on a 235/40. because of the progressive spring rates on the Bilstein, at the thickest part of the spring comes about 1/4 inch from the wheel. Is this too close and will I destroy my suspension or wheels?
and how low do these coilers go. lmk if you have any experience with fitment this close. thanks |
Drives: Bone stock
235 on 9.5 is a lot of stretch my guy.
Sent from my SM-N960U using Tapatalk |
1/4" is plenty of clearance imho
I never tried to slam mine, the lower you go the more bump stop you use and the suspension becomes more uncomfortable, iirc I set them around 1"-1.5" lower then stock. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Nick826 (12-01-2020) |
Drives: '23 BRZ
3mm would be my min static clearance, 1/4" is 6+mm, IMO you're OK.
FWIW 235/40-18 is okeedokee on 18x9.5, it's the max recommended wheel width. Would be a "stretch" on 10".... |
Human
Drives: 2015 BRZ Black
235/40 on 18x9.5 is a bit of a stretch. I run 235/40 on 18x8.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#7 | |
Drives: '23 BRZ
For maximum lateral grip and responsiveness, you would want to be at the wider end of the wheel width range. Personally, I'd run 245/35-18 on 18x9.5", and I'd run 225/40-18 on 18x8. |
my stretch is fine. looking to see if you guys have personally ran something this close. my wheels poke aswell and think camber bets would make my clearance even closer. would camber adjustable top hats solve this ?
A photo of the stretch. Very mild
#10 | |
30 minute maintenance
Drives: My18 wrxsti
#11 | |
Drives: '23 BRZ
All I'm saying is if I'm "guy A", I'd be running 245/35-18s on his 9.5" wheels, and if I'm "guy B" I'd be running 225/40-18 on his 8" wheels. But they're both OK with 235/40-18, although they are slightly larger in diameter vs. stock size, not a biggie... |
| The Following User Says Thank You to ZDan For This Useful Post: | gen3v8 (12-02-2020) |
| (Close)WTB:Aus GT Black interior(Close) | Ry.ruzn | Want-To-Buy Requests | 0 | 04-20-2016 01:55 AM |
| How close is too close?: Gap between tire & spring perch | kodyo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-20-2015 01:32 PM |
| CLOSE/DONE | Jman1759 | Want-To-Buy Requests | 2 | 07-22-2015 02:58 PM |
| Please Close. | dizzario | Wheels and Tires | 1 | 05-11-2014 10:40 PM |
| End. Close please | Figo | NY / NJ / CT / PA | 7 | 05-09-2014 01:32 PM |
