Old 11-28-2020, 02:57 PM   #1
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
SOLD: CSG spec Tein SRC w/ EDFC Active PRO
For sale is a set of CSG-spec Tein SRC coilovers. Development thread can be found at https://www.ft86club.com/forums/showthread.php?t=82796. It comes equipped with Tein's Electronic Damping Force Controller (EDFC) Active PRO kit (https://www.evasivemotorsports.com/s...ontroller-kit/).
Specifications:
• 10kg/mm front spring rate
• 12kg/mm rear spring rate
• Steel Construction
• Mono Tube internal construction
• Inverted design for strut type front and rear
• Ride Height adjustable via threaded body and spring seats
• 16 × 16 way adjustable dampers, compression and rebound separately adjustable
• Pillow ball upper mounts for increased steering feel, front and rear
• Upper and lower camber adjustment on front
• Caster adjustment on front
• Dual EDFC (Electronic Damping Force Controller) installed
• Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
EDFC Active PRO:
EDFC ACTIVE PRO is a high-spec version of EDFC ACTIVE, which enables automatic adjustment of damping force according to the changes in longitudinal G-force and vehicle speed, and comes with new and upgraded functions. Newly-added features, such as individual adjustment of 4 shock absorbers, lateral (cornering) G-actuated automatic adjustment, vehicle speed pulse input and 2 additional input ports to communicate with drivers, are sure to bring out the full potential of each shock absorber as well as the vehicle itself.
The shocks were rebuilt and since have maybe 1-2 weekends (replaced with Penskes). Since they are used, it will include all of the extra EDFC components to refresh the motors and wiring, since one or two need it.
Overall, this is almost a $6000 system after tax ($4850 for CSG-spec system, $700 for EDFC Active PRO). Asking $3000 shipped in Con-U.S. via PayPal with tracking & insurance.
Jyn is offline
Old 11-29-2020, 11:45 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
GLWS! Have these in my car and they are awesome. How did the EDFC perform with them?
Jdmjunkie is offline
The Following User Says Thank You to Jdmjunkie For This Useful Post:
Jyn (11-30-2020)
Old 11-29-2020, 11:59 PM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'll let you know
Or the OP can first ha
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
The Following User Says Thank You to Dave-ROR For This Useful Post:
Jdmjunkie (11-30-2020)
Old 11-30-2020, 12:37 AM   #4
Jyn
Noob
Jyn's Avatar
Sold.
Jyn is offline
FS: Tein Edfc Active Pro byun Brakes, Suspension, Chassis 9 01-14-2017 05:21 PM
FS: Tein EDFC Active Pro byun Brakes, Suspension, Chassis 6 11-18-2016 01:33 PM
Tein EDFC PRO + GPS Install Manual (Eng) Trap63 DIY (Do-It-Yourself) Guides 0 10-18-2015 08:14 AM
Tein Active EDFC?? Yes please :) RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 91 04-14-2014 09:44 AM
